Ansys aaS connection with matlab
I was able to connect matlab with ansys using the toolbox provided.
my problem is that i don't know how to transfer data from matlab to ansys. for example if I create a variable on matlab say:
a = 22;
This line doesn't work:
mapdlResult=char(iCoMapdlUnit.executeCommandToString('aas_parameter_test= a'))
is there a certain way of doing it? I cant seem to figure it out
hello, I'm sure you hope your find a solution for your problem.
I'm not sure but when you input mapdlResult=char(iCoMapdlUnit.executeCommandToString('aas_parameter_test= a'))
The char will make it as just 'a', isn't it ?
Good luck !
