Distributed solver
I'm playing with Distributed solving in version 19.4 R2. My cluster has 3 PCs. In a couple minutes after Solver started the job has failed.
I can't find what caused it. Could you please review log file and advise?
Thanks, Nick
«1
  • tsiriakstsiriaks 3240 El Camino Real #290, Irvine, CA 92602Member
    edited September 2019
    Hi Nick,
    Sorry, ANSYS employees are not allowed to download file attachments. Could you post this as an inline text or post screenshots inline ?
    Are you using ANSYS Student (free) version ?
    Is this Mechanical, Fluids, or Electronics product ?
    Win
    Win, it looks like a directory error.
  • kolyan007kolyan007 Member
    edited October 2019
    Thanks Peter, good spotting. That folder ScrCA9A is missing under _ProjectScratch. How I can find why Mechanical trying to access it? Could it be because of some references in projects?
    edited October 2019
    Thanks for the screenshot Peter.
    So, this is Mechanical + ANSYS RSM.
    I'm gonna need much more information to proceed. Note: That folder should be automatically created by the solver.
    When you said 'cluster' , do you mean it has job scheduler or it's just 3 machines with no job scheduler connecting to each other ? If you have your own scheduler, what's the name of it ?
    How do you submit the jobs ? Please show screenshots of the workflow and setup in both Workbench and RSM Configuration GUI's
    Post screenshot of the top part of RSM Job Report.
    Win
    edited October 2019
    Thanks for your reply. I was thinking there is some incompatibility between my 3 machine cluster and R2, so I did reinstall OS on master machine (maincad) that using to send tasks to slaves in cluster, install R3 on it and install R3 on slaves, then replicate settings.
    I don't have my own scheduler. All machines connecting to each other.
    There are a screenshots with my config below.
    ARC configuration on master
    ARC configuration on masterARC configuration on masterARC configuration on master
    Note: I'm not sure why, but Service Management running by cluster02user. Not sure how to change to default.
    RSM config on master:
    RSM configuration on master
    RSM configuration on masterRSM configuration on master
    Somehow Queues refresh fails.
    This is after I deleted credentials for cluster01
    RSM config for cluster02
    And RSM config for localhost
    These 3 services running on each machine in cluster:
    Master:
    Services on master
    Cluster01
    Services on cluster01
    Cluster02
    Services on cluster02
    My Solve Process settings:
    Solve settings
    Solve in mechanical
    Also I've tested telnet to port 9195 and SMB in Windows, there is no issues from OS perspective. All machines using same credentials.
    Additionally I've found that if I run: arcconfig node modify %COMPUTERNAME% -mn maincad                  so test in RSM will go in schedule mode, but if I replace my master node with %COMPUTERNAME%, a test will go through fine. What options is correct?
    Cluster01 port 9195 listening
    Cluster02 port 9195 listening
    edited October 2019
    ok, so you are using ANSYS own light-weight scheduler (ARC).
    I normally use commands to set this, so I'm not familiar with settings on the ARC Config GUI but I've asked a colleague to help check it.
    However, I see a lot of mis-configurations.
    Essentially, this is what you need to do to properly setup RSM-ARC
    Create share directory
    Create a directory on a machine that you would like to use as the staging directory.
    For this example, I will use e:RSMStaging
    Now share that directory out to all solving machines and 'submit host' so that anyone can read and write to it.
    Right click on RSMStaging and select Properties Select Sharing Tab
    Click on Share...
    Type in:
    Everyone
    And click Add
    Type in:
    Domain Computers
    Click Add
    Type in:
    Domain Users
    Click Add
    Give each of the users Read/Write access
    Then click "Share"
    Then click Done
    On 'submit host' machine (This is a dedicated node. Do not install this on all nodes)
    This is the machine that receives requests from clients, then queues and distributes jobs to solve on solving machines. This machine itself can also be a solving machine.
    Two components are required here:
    1. RSM Launcher service, which deals with the communications between client machine and this machine
    2. ARC Master service is one of the two parts of the ARC job scheduler, a light-weight job scheduler that ANSYS provides. This part deals with the communications between RSM Launcher and solving machine(s) , essentially, queueing and distributing jobs to solving machine(s).
    On solving machine(s)
    Install ARC Node service, which is used for communicating with the ARC Master service.
  • jcalleryjcallery Member
    edited October 2019
    Hi Nick,
    There seems to be a number of different issues to look at here.
    First, please uninstall the ARC Master and RSM Launcher services from the two machines that are NOT the head node.
    You can do this from the command line by doing the following:
    Start -> Type cmd -> Right click on Command Prompt and select Run As administrator
    At the prompt type:
    cd /d "c:program filesansys incv195RSMin"
    ansunconfigrsm -launcher
    cd /d "c:program filesansys incv195RSMARC oolswinx64"
    uninstallservice -arcmaster
    This should leave the ARC Node service running on MainCad,Cluster01,Cluster02
    This should leave the ARC Master and Launcher service running on MainCad only.
    Once that is done, go to MainCad and run the admin command prompt as state above, then type:
    cd /c "c:program filesansys incv195RSMARC oolswinx64"
    arcnodes
    arcqueues
    Then please paste a screenshot of that.
    Thank you,
    Jake
    edited October 2019
    Continued
    On client machines. Note All info here is the same on any client machine. The Submit Host is the dedicated node above. Do not use local machine information.
    Launch RSM Configuration GUI
    Once you are in the GUI, click the plus sign on the top left then fill out name or its IP address of the Submit Host machine and OS.
    Once, this is done, click “Apply”
    Go to “File Management” tab , Select "Operating System File Transfer" , Put in the share path to the RSMStaging directory you shared earlier (again, this is the same UNC path that you setup to share above, do not use local machine information)
    Then, Go to “Queues” tab , click “Import/Refresh Cluster Queues” , then specify your login username and password. This will bring up all the queues. You can enable and disable any queue that you like.
    Then make sure that port 9195 is open between the client and the ‘submit host’ machines.
    edited October 2019
    sounds good, please keep us posted
    Win
    edited October 2019
    Just checked RSM Cluster Load Monitoring on HEAD node, it shows only 1 node, not 3. I've manually created another queue and added another nodes to it, but it doesn't help.
    My queues and RSM Cluster output on HEAD node is below:
    edited October 2019
    Followed ANSYS RSM user guide to finalize my cluster setup.
    Got 3 nodes under RSM Cluster Monitoring and tests were fine, but there is an error when I tried to solve my project. Maincad is my Submit Host+solver, Cluster02 is only solver. Please advise what could be wrong?
    edited October 2019
    Looks like something is blocking the IntelMPI processes.
    Firewall / User Account Control / Antivirus / etc...
    You could try IBM MPI instead.
    First make sure IBM/Platform MPI is installed on all machines.
    Then In Mechanical go to Solve Process Settings -> Select your config -> Advanced
    In the Additional Command Line Arguments add:
    -mpi ibmmpi
    Then try it again.
    Thank you,
    Jake
    edited October 2019
    Thanks for advise. I've installed MPI services only on Submit host. I will add it to remote solvers and add these CMD arguments.
    edited October 2019
    What arguments should I use if I will be using Intel MPI? (once MPI installed on all machines)
    What installation set of IBM MPI would be the best for Windows 10? (Service Mode, Service Only or HPC mode)
    edited October 2019
    Right, so IBM MPI is installed on all machines as Service Mode, hope it's correct set. Also -mpi ibmmpi as argument also added. Telnet to TCP 8636 from Submit Host to solvers is ok.
    Now solving working, but I don't see any CPU load on my solvers. If there anything else to check?
    Start running job commands ...
    Running on machine : Maincad
    Current Directory: c:RSMStagingofwkpry5.3rq
    Running command: C:Program FilesANSYS Incv195SECSolverExecutionController
    unsec.bat
    Redirecting output to  None
    Final command arg list : ['C:\Program Files\ANSYS Inc\v195\SEC\SolverExecutionController\runsec.bat']
    Running Process
    Running Solver : C:Program FilesANSYS Incv195ansysinwinx64ANSYS195.exe -b nolist -s noread -p ansys -mpi ibmmpi -i remote.dat -o solve.out -dis -machines maincad:1:cluster01:1:cluster02:1 -dir "cRSMStaging/ofwkpry5.3rq"
    WARNING: No cached password or password provided.
             use '-pass' or '-cache' to provide password
     *** The AWP_ROOT195 environment variable is set to: C:Program FilesANSYS Incv195
     *** The AWP_LOCALE195 environment variable is set to: en-us
     *** The ANSYS195_DIR environment variable is set to: C:Program FilesANSYS Incv195ANSYS
     *** The ANSYS_SYSDIR environment variable is set to: winx64
     *** The ANSYS_SYSDIR32 environment variable is set to: intel
     *** The CADOE_DOCDIR195 environment variable is set to: C:Program FilesANSYS Incv195CommonFileshelpen-ussolviewer
     *** The CADOE_LIBDIR195 environment variable is set to: C:Program FilesANSYS Incv195CommonFilesLanguageen-us
     *** The LSTC_LICENSE environment variable is set to: ANSYS
     *** The P_SCHEMA environment variable is set to: C:Program FilesANSYS Incv195AISOLCADIntegrationParasolidPSchema
     *** The TEMP environment variable is set to: C:UsersUserAppDataLocalTemp
    edited October 2019
    This seems good (and by the way, the Service Mode for IBM MPI is the correct choice) .
    If you open up Task Manager on solving machines do you see any ANSYS.exe or ANSYS195.exe ?
    edited October 2019
    Only Submit host has some activity with ANSYS, solvers don't show it. Weird.
    This screenshot from Submit host:
    edited October 2019
    Please post a screenshot of your Solution properties if submitting from workbench or post the screenshot of your Solve Process Settings and the advanced tab for the solve process setting you are using.
    Thank you,
    Jake
    edited October 2019
    Yesterday I was playing with Intel MPI as previously I've seen some load on solvers with it. The screenshot with Solve Process Settings and Advanced tab is below.
    So I've tried with -mpi intelmpi argument and without. The result was the same, i.e. the solving process started on all machines, CPU load was 100% but only for a couple of minutes, then I got MPI_Abort error (full error message is also below).
    Note: Regarding that Invalid working directory value= CRSMStaging/aokqqj0p.5k1 message it's weird as folder actually exists and accessible by solvers. Not sure why it has wrong slashes here.
    Also, I do have NVidia Quadro GPU in each machine. Is it reasonable to enable GPU Acceleration to improve performance?
    Error message (omitted):
    send of 20 bytes failed.
    Command Exit Code: 99
    application called MPI_Abort(MPI_COMM_WORLD, 99) - process 0
    [[email protected]] ..hydrautilssocksock.c (420): write error (Unknown error)
    [[email protected]] ..hydrautilslaunchlaunch.c (121): shutdown failed, sock 648, error 10093
    ClusterJobs Command Exit Code: 99
    Saving exit code file: C:RSMStagingaokqqj0p.5k1exitcode_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout
        Exit code file: C:RSMStagingaokqqj0p.5k1exitcode_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout has been created.
    Saving exit code file: C:RSMStagingaokqqj0p.5k1exitcodeCommands_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout
        Exit code file: C:RSMStagingaokqqj0p.5k1exitcodeCommands_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout has been created.
    =======SOLVE.OUT FILE======
    solve -->  *** FATAL ***
    solve --> Attempt to run ANSYS in a distributed mode failed.
    solve -->   The Distributed ANSYS process with MPI Rank ID =    4 is not responding.
    solve -->   Please refer to the Distributed ANSYS Guide for detailed setup and configuration information.
    ClusterJobs Exiting with code: 99
    Individual Command Exit Codes are: [99]
    Full error log:
    RSM Version: 19.5.420.0, Build Date: 30/07/2019 57:06 am
    RSM File Version: 19.5.0-beta.3+Branch.release-19.5.Sha.9c15e0a3e0a608e8efe8c568e494d2160788d025
    RSM Library Version: 19.5.0.0
    Job Name: Annulus_Thread_MAX_Sludge-SidWalls=No Separation,rhoSludge=2,3,t=0-DP0-Model (B4)-Static Structural (B5)-Solution (B6)
        Type: Mechanical_ANSYS
        Client Directory: C:TestProject_ProjectScratchScr6531
        Client Machine: Maincad
        Queue: Default [localhost, default]
        Template: Mechanical_ANSYSJob.xml
    Cluster Configuration: localhost [localhost]
        Cluster Type: ARC
        Custom Keyword: blank
        Transfer Option: NativeOS
        Staging Directory: C:RSMStaging
        Delete Staging Directory: True
        Local Scratch Directory: blank
        Platform: Windows
        Cluster Submit Options: blank
        Normal Inputs: [*.dat,file*.*,*.mac,thermal.build,commands.xml,SecInput.txt]
        Cancel Inputs: [file.abt,sec.interrupt]
        Excluded Inputs: [-]
        Normal Outputs: [*.xml,*.NR*,CAERepOutput.xml,cyclic_map.json,exit.topo,file*.dsub,file*.ldhi,file*.png,file*.r0*,file*.r1*,file*.r2*,file*.r3*,file*.r4*,file*.r5*,file*.r6*,file*.r7*,file*.r8*,file*.r9*,file*.rd*,file*.rst,file.BCS,file.ce,file.cm,file.cnd,file.cnm,file.DSP,file.err,file.gst,file.json,file.nd*,file.nlh,file.nr*,file.PCS,file.rdb,file.rfl,file.spm,file0.BCS,file0.ce,file0.cnd,file0.err,file0.gst,file0.nd*,file0.nlh,file0.nr*,file0.PCS,frequencies_*.out,input.x17,intermediate*.topo,Mode_mapping_*.txt,NotSupportedElems.dat,ObjectiveHistory.out,post.out,PostImage*.png,record.txt,solve*.out,topo.err,toput,vars.topo,SecDebugLog.txt,secStart.log,sec.validation.executed,sec.envvarvalidation.executed,sec.failure]
        Failure Outputs: [*.xml,*.NR*,CAERepOutput.xml,cyclic_map.json,exit.topo,file*.dsub,file*.ldhi,file*.png,file*.r0*,file*.r1*,file*.r2*,file*.r3*,file*.r4*,file*.r5*,file*.r6*,file*.r7*,file*.r8*,file*.r9*,file*.rd*,file*.rst,file.BCS,file.ce,file.cm,file.cnd,file.cnm,file.DSP,file.err,file.gst,file.json,file.nd*,file.nlh,file.nr*,file.PCS,file.rdb,file.rfl,file.spm,file0.BCS,file0.ce,file0.cnd,file0.err,file0.gst,file0.nd*,file0.nlh,file0.nr*,file0.PCS,frequencies_*.out,input.x17,intermediate*.topo,Mode_mapping_*.txt,NotSupportedElems.dat,ObjectiveHistory.out,post.out,PostImage*.png,record.txt,solve*.out,topo.err,toput,vars.topo,SecDebugLog.txt,sec.solverexitcode,secStart.log,sec.failure,sec.envvarvalidation.executed]
        Cancel Outputs: [file*.err,solve.out,secStart.log,SecDebugLog.txt]
        Excluded Outputs: [-]
        Inquire Files:
          normal: [*.xml,*.NR*,CAERepOutput.xml,cyclic_map.json,exit.topo,file*.dsub,file*.ldhi,file*.png,file*.r0*,file*.r1*,file*.r2*,file*.r3*,file*.r4*,file*.r5*,file*.r6*,file*.r7*,file*.r8*,file*.r9*,file*.rd*,file*.rst,file.BCS,file.ce,file.cm,file.cnd,file.cnm,file.DSP,file.err,file.gst,file.json,file.nd*,file.nlh,file.nr*,file.PCS,file.rdb,file.rfl,file.spm,file0.BCS,file0.ce,file0.cnd,file0.err,file0.gst,file0.nd*,file0.nlh,file0.nr*,file0.PCS,frequencies_*.out,input.x17,intermediate*.topo,Mode_mapping_*.txt,NotSupportedElems.dat,ObjectiveHistory.out,post.out,PostImage*.png,record.txt,solve*.out,topo.err,toput,vars.topo,SecDebugLog.txt,secStart.log,sec.validation.executed,sec.envvarvalidation.executed,sec.failure]
          cancel: [file*.err,solve.out,secStart.log,SecDebugLog.txt]
          failure: [*.xml,*.NR*,CAERepOutput.xml,cyclic_map.json,exit.topo,file*.dsub,file*.ldhi,file*.png,file*.r0*,file*.r1*,file*.r2*,file*.r3*,file*.r4*,file*.r5*,file*.r6*,file*.r7*,file*.r8*,file*.r9*,file*.rd*,file*.rst,file.BCS,file.ce,file.cm,file.cnd,file.cnm,file.DSP,file.err,file.gst,file.json,file.nd*,file.nlh,file.nr*,file.PCS,file.rdb,file.rfl,file.spm,file0.BCS,file0.ce,file0.cnd,file0.err,file0.gst,file0.nd*,file0.nlh,file0.nr*,file0.PCS,frequencies_*.out,input.x17,intermediate*.topo,Mode_mapping_*.txt,NotSupportedElems.dat,ObjectiveHistory.out,post.out,PostImage*.png,record.txt,solve*.out,topo.err,toput,vars.topo,SecDebugLog.txt,sec.solverexitcode,secStart.log,sec.failure,sec.envvarvalidation.executed]
          RemotePostInformation: [RemotePostInformation.txt]
          SolutionInformation: [solve.out,file.gst,file.nlh,file0.gst,file0.nlh,file.cnd]
          PostDuringSolve: [file.rcn,file.redm,file.rfl,file.rfrq,file.rmg,file.rdsp,file.rsx,file.rst,file.rth,solve.out,file.gst,file.nlh,file0.gst,file0.nlh,file.cnd]
          transcript: [solve.out,monitor.json]
    Submission in progress...
    Created storage directory C:RSMStagingaokqqj0p.5k1
    Runtime Settings:
        Job Owner: MAINCADUser
        Submit Time: Tuesday, 8 October 2019 11:40 pm
        Directory: C:RSMStagingaokqqj0p.5k1
    Uploading file: C:TestProject_ProjectScratchScr6531ds.dat
    emote.dat
    Uploading file: C:TestProject_ProjectScratchScr6531commands.xml
    Uploading file: C:TestProject_ProjectScratchScr6531SecInput.txt
    39898.74 KB, .08 sec (498807.21 KB/sec)
    JobType is: Mechanical_ANSYS
    Final command platform: Windows
    RSM_PYTHON_HOME=C:Program FilesANSYS Incv195commonfilesCPython2_7_15winx64Releasepython
    RSM_HPC_JOBNAME=Mechanical
    Distributed mode requested: True
    RSM_HPC_DISTRIBUTED=TRUE
    Running 1 commands
    Job working directory: C:RSMStagingaokqqj0p.5k1
    Number of CPU requested: 12
    AWP_ROOT195=C:Program FilesANSYS Incv195
    Checking queue default exists ...
    JobId was parsed as: 4
    Job submission was successful.
    Job is running on hostname Maincad
    Job user from this host: User
    Starting directory: C:RSMStagingaokqqj0p.5k1
    Reading control file C:RSMStagingaokqqj0p.5k1control_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsm ....
    Correct Cluster verified
    Cluster Type: ARC
    Underlying Cluster: ARC
        RSM_CLUSTER_TYPE = ARC
    Compute Server is running on MAINCAD
    Reading commands and arguments...
        Command 1: %AWP_ROOT195%SECSolverExecutionController
    unsec.bat, arguments: , redirectFile: None
    Running from shared staging directory ...
        RSM_USE_LOCAL_SCRATCH = False
        RSM_LOCAL_SCRATCH_DIRECTORY =
        RSM_LOCAL_SCRATCH_PARTIAL_UNC_PATH =
    Cluster Shared Directory: C:RSMStagingaokqqj0p.5k1
        RSM_SHARE_STAGING_DIRECTORY = C:RSMStagingaokqqj0p.5k1
    Job file clean up: True
    Use SSH on Linux cluster nodes: False
        RSM_USE_SSH_LINUX = False
    LivelogFile: NOLIVELOGFILE
    StdoutLiveLogFile: stdout_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.live
    StderrLiveLogFile: stderr_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.live
    Reading input files...
        *.dat
        file*.*
        *.mac
        thermal.build
        commands.xml
        SecInput.txt
    Reading cancel files...
        file.abt
        sec.interrupt
    Reading output files...
        *.xml
        *.NR*
        CAERepOutput.xml
        cyclic_map.json
        exit.topo
        file*.dsub
        file*.ldhi
        file*.r0*
        file*.r1*
        file*.r2*
        file*.r3*
        file*.r4*
        file*.r5*
        file*.r6*
        file*.r7*
        file*.r8*
        file*.r9*
        file*.rd*
        file*.rst
        file.BCS
        file.ce
        file.cm
        file.cnd
        file.cnm
        file.DSP
        file.err
        file.gst
        file.json
        file.nd*
        file.nlh
        file.nr*
        file.PCS
        file.rdb
        file.rfl
        file.spm
        file0.BCS
        file0.ce
        file0.cnd
        file0.err
        file0.gst
        file0.nd*
        file0.nlh
        file0.nr*
        file0.PCS
        frequencies_*.out
        input.x17
        intermediate*.topo
        Mode_mapping_*.txt
        post.out
        record.txt
        solve*.out
        topo.err
        toput
        vars.topo
        SecDebugLog.txt
        secStart.log
        sec.failure
        *.xml
        *.NR*
        CAERepOutput.xml
        cyclic_map.json
        exit.topo
        file*.dsub
        file*.ldhi
        file*.r0*
        file*.r1*
        file*.r2*
        file*.r3*
        file*.r4*
        file*.r5*
        file*.r6*
        file*.r7*
        file*.r8*
        file*.r9*
        file*.rd*
        file*.rst
        file.BCS
        file.ce
        file.cm
        file.cnd
        file.cnm
        file.DSP
        file.err
        file.gst
        file.json
        file.nd*
        file.nlh
        file.nr*
        file.PCS
        file.rdb
        file.rfl
        file.spm
        file0.BCS
        file0.ce
        file0.cnd
        file0.err
        file0.gst
        file0.nd*
        file0.nlh
        file0.nr*
        file0.PCS
        frequencies_*.out
        input.x17
        intermediate*.topo
        Mode_mapping_*.txt
        post.out
        record.txt
        solve*.out
        topo.err
        toput
        vars.topo
        SecDebugLog.txt
        sec.solverexitcode
        secStart.log
        sec.failure
    Reading exclude files...
        stdout_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout
        stderr_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout
        hosts.dat
        ClusterJobCustomization.xml
        ClusterJobs.py
        clusterjob_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.sh
        clusterjob_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.bat
        inquire.request
        inquire.confirm
        request.upload.rsm
        request.download.rsm
        wait.download.rsm
        scratch.job.rsm
        volatile.job.rsm
        restart.xml
        cancel_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout
        liveLogLastPositions_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsm
        stdout_782e78b5-2c00-45fa-b7ac-6976aa49c2cf_kill.rsmout
        stderr_782e78b5-2c00-45fa-b7ac-6976aa49c2cf_kill.rsmout
        sec.interrupt
        stdout_782e78b5-2c00-45fa-b7ac-6976aa49c2cf_*.rsmout
        stderr_782e78b5-2c00-45fa-b7ac-6976aa49c2cf_*.rsmout
        stdout_task_*.live
        stderr_task_*.live
        control_task_*.rsm
        stdout_task_*.rsmout
        stderr_task_*.rsmout
        exitcode_task_*.rsmout
        exitcodeCommands_task_*.rsmout
        file.abt
    Reading environment variables...
        RSM_IRON_PYTHON_HOME = C:Program FilesANSYS Incv195commonfilesIronPython
        RSM_TASK_WORKING_DIRECTORY = C:RSMStagingaokqqj0p.5k1
        RSM_QUEUE_NAME = default
        RSM_CONFIGUREDQUEUE_NAME = Default
        RSM_COMPUTE_SERVER_MACHINE_NAME = Maincad
        RSM_HPC_JOBNAME = Mechanical
        RSM_HPC_DISPLAYNAME = Annulus_Thread_MAX_Sludge-SidWalls=No Separation,rhoSludge=2,3,t=0-DP0-Model (B4)-Static Structural (B5)-Solution (B6)
        RSM_HPC_CORES = 12
        RSM_HPC_DISTRIBUTED = TRUE
        RSM_HPC_NODE_EXCLUSIVE = FALSE
        RSM_HPC_QUEUE = default
        RSM_HPC_USER = MAINCADUser
        RSM_HPC_WORKDIR = C:RSMStagingaokqqj0p.5k1
        RSM_HPC_JOBTYPE = Mechanical_ANSYS
        RSM_HPC_ANSYS_LOCAL_INSTALL_DIRECTORY = C:Program FilesANSYS Incv195
        RSM_HPC_VERSION = 195
        RSM_HPC_STAGING = C:RSMStagingaokqqj0p.5k1
        RSM_HPC_LOCAL_PLATFORM = Windows
        RSM_HPC_CLUSTER_TARGET_PLATFORM = Windows
        RSM_HPC_STDOUTFILE = stdout_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout
        RSM_HPC_STDERRFILE = stderr_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.rsmout
        RSM_HPC_STDOUTLIVE = stdout_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.live
        RSM_HPC_STDERRLIVE = stderr_782e78b5-2c00-45fa-b7ac-6976aa49c2cf.live
        RSM_HPC_SCRIPTS_DIRECTORY_LOCAL = C:Program FilesANSYS Incv195RSMConfigscripts
        RSM_HPC_SCRIPTS_DIRECTORY = C:Program FilesANSYS Incv195RSMConfigscripts
        RSM_HPC_SUBMITHOST = localhost
        RSM_HPC_STORAGEID = <JobId>    <id>a7ab7b67-dc3d-44cb-a665-813ffa216eee</id>    <nativeId>Mechanical=LocalOS#localhost$C:RSMStagingaokqqj0p.5k1</nativeId>    <timestamp>Tuesday, October 08, 2019 10:40:05.011 AM</timestamp>    <fullyDefined>True</fullyDefined></JobId>
        RSM_HPC_PLATFORMSTORAGEID = C:RSMStagingaokqqj0p.5k1
        RSM_HPC_NATIVEOPTIONS =
        ARC_ROOT = C:Program FilesANSYS Incv195RSMConfigscripts....ARC
        RSM_HPC_KEYWORD = ARC
        RSM_PYTHON_LOCALE = en-us
    Reading AWP_ROOT environment variable name ...
        AWP_ROOT environment variable name is: AWP_ROOT195
    Reading Low Disk Space Warning Limit ...
        Low disk space warning threshold set at: 2.0GiB
    Reading File identifier ...
        File identifier found as: 782e78b5-2c00-45fa-b7ac-6976aa49c2cf
    Done reading control file.
    RSM_AWP_ROOT_NAME = AWP_ROOT195
    AWP_ROOT195 install directory: C:Program FilesANSYS Incv195
    RSM_MACHINES = maincad:4:cluster01:4:cluster02:4
    Number of nodes assigned for current job = 3
    Machine list: ['maincad', 'cluster01', 'cluster02']
    Checking DisableUNCCheck ...
    Unable to read registry for HKEY_CURRENT_USERSoftwareMicrosoftCommand Processor
    Ignore verifying DisableUNCCheck, you may check it manually if not already done so.
    Current Directory: C:RSMStagingaokqqj0p.5k1
    unsec.bat
    Running Process
    Running Solver : C:Program FilesANSYS Incv195ansysinwinx64ANSYS195.exe -b nolist -s noread -acc nvidia -na 1 -p ansys -mpi intelmpi -i remote.dat -o solve.out -dis -machines maincad:4:cluster01:4:cluster02:4 -dir "CRSMStaging/aokqqj0p.5k1"
     *** FATAL ***
      (specified working directory does not exist)
     *** NOTE ***
      USAGE: C:Program FilesANSYS Incv195ANSYSinwinx64ANSYS.EXE
                         [-d device name] [-j job name]
                         [-b list|nolist] [-m scratch memory(mb)]
                         [-s read|noread] [-g] [-db database(mb)]
                         [-p product] [-l language]
                         [-dyn] [-np #] [-mfm]
                         [-dvt] [-dis] [-machines list]
                         [-i inputfile] [-o outputfile]
                         [-ser port] [-scport port]
                         [-scname couplingname] [-schost hostname]
                         [-smp] [-mpi intelmpi|ibmmpi|msmpi]
                         [-dir working_directory ]
     *** FATAL ***
     *** NOTE ***
                         [-acc nvidia] [-na #]
     *** FATAL ***
     *** NOTE ***
     *** FATAL ***
     *** NOTE ***
     *** FATAL ***
     *** NOTE ***
     *** FATAL ***
     *** NOTE ***
     *** FATAL ***
     *** NOTE ***
     *** FATAL ***
     *** NOTE ***
    edited October 2019
    If you are trying to distribute across multiple machines your staging directory can't be a local drive "c:"
    You will need to share that directory and in the staging directory setting use the unc path to that shared directory eg:
    \maincadRSMStaging
    Please be sure to set the RSMStaging share security to be open to all users and machines.
    Thank you,
    Jake
