Where I set the Tensile Yield per material?
José MantovaniJosé Mantovani São Paulo, BrazilMember
Hello Guys!
I try to do the Safety Factor in my structural analysis but I received a message that I should set the Tensile Yield before Solve the solution. I see, I have a option of input a custom value, but it not work. How can I make it? I dont find where to put this parameter on Engineering Data.
Thanks a lot!
Mantovani.
  • pglpgl Portland, Oregon, USAMember
    edited March 2018
    Here's the online help explaining how to use the Max Tensile Stress Safety Tool.
    I think you just need to select Tensile Yield Per Material
    edited March 2018
    Engineering Data has Tensile Yield and Ultimate on some materials in the database.
    If the material doesn't have that defined, you can drag that property out of the toolbox.
    then type in the values.
  • José MantovaniJosé Mantovani São Paulo, BrazilMember
    edited March 2018
    Thanks for the attetion sirs! Pgl, I stay using a "added material", Polyamide 6. So, this method don't work, this material haven't in the Engineering Data. I will try as Peter said. But, thanks a lot!
    Good night!
  • rachelxiaoqirachelxiaoqi Member
    edited May 14
    Hi, I would like to ask where can i get the choice of Tensile Yield Strength, Compressive Yield Strength, Tensile Ultimate Strength and Compressive Ultimate Strength in the Strength category as for mine, there are only Orthotropic Stress Limits, Orthotropic Strain Limits, Tsai-Wu Constants, Puck Constants and LaRc03/04 Constants.
