Run Fluent adjoint solver in workbench
Hi all,
Is there any way to run Fluent adjoint solver in workbench?
    edited October 2019
    Yes just go to Ribbon and define your observable and run the Adjoint Solver
  • danielxu1danielxu1 Member
    edited October 2019
    Hi Amine,
    Thanks for your reply. I am still confused about this. First I got a converged CFD result in workbench and then set up my observable and AD solver in Fluent. I need to use cluster to run the case, in CFX I just right click the solution and update, but it doesn't work in Fluent, the AD solver can not be run.
    Kind Regards,
    Daniel
    edited October 2019
    Use automatic modification feature so that Fluent run the Adjoint solver based on journal.
