Parrafin Melting - Scale Problems
My simulation consists in melting paraffin inside a heat exchanger using hot water (geometry is bellow). Initial conditions of water inlet temperature at 52?C, flow rate at 1.5l/s and the paraffin initially  at 18?C.
Geometry
My first step was to validate my model with an published article, and using real scale it works but took more than one month simulating to finish.
Now, I want to reduce the model scale to do all the tests I need. I reduced scale (x,y and z to 0.5) and now I received this error         "Stabilizing temperature to enhance linear solver robustness." and the model is not converging anymore. I attached the summary with the methods used.
Can anyone help me?
  • edited October 2019
    Models
    Model Settings
    Space 3D
    Time Unsteady, 1st-Order Implicit
    Viscous RNG k-epsilon turbulence model
    Wall Treatment Standard Wall Functions
    RNG Differential Viscosity Model Disabled
    RNG Swirl Dominated Flow Option Disabled
    Heat Transfer Enabled
    Solidification and Melting Enabled
    Radiation None
    Species Disabled
    Coupled Dispersed Phase Disabled
    NOx Pollutants Disabled
    SOx Pollutants Disabled
    Soot Disabled
    Mercury Pollutants Disabled
    Structure Disabled
    Material Properties
    Material: copper (solid)
    Property Units Method Value(s)
    Density kg/m3 constant 8978
    Cp (Specific Heat) j/kg-k constant 381
    Thermal Conductivity w/m-k constant 387.6
    Material: parafin (fluid)
    Density kg/m3 constant 750
    Cp (Specific Heat) j/kg-k constant 2000
    Thermal Conductivity w/m-k constant 0.2
    Viscosity kg/m-s constant 0.008
    Molecular Weight kg/kmol constant 18.0152
    Thermal Expansion Coefficient 1/k constant 0.00259
    Pure Solvent Melting Heat j/kg constant 255000
    Solidus Temperature k constant 314.15
    Liquidus Temperature k constant 317.15
    Speed of Sound m/s none #f
    Material: water-liquid (fluid)
    Density kg/m3 constant 998.2
    Cp (Specific Heat) j/kg-k constant 4182
    Thermal Conductivity w/m-k constant 0.6
    Viscosity kg/m-s constant 0.001003
    Pure Solvent Melting Heat j/kg constant 0
    Solidus Temperature k constant 0
    Liquidus Temperature k constant 0
    Cell Zone Conditions
    Zones
    name id type
    fin-cooper 11 solid
    tank-pcm 9 fluid
    pipe-water 10 fluid
    Setup Conditions
    fin-cooper
    Condition Value
    Frame Motion? no
    Mesh Motion? no
    tank-pcm
    Condition Value
    Frame Motion? no
    Mesh Motion? no
    pipe-water
    Condition Value
    Material Name water-liquid
    Frame Motion? no
    Mesh Motion? no
    Boundary Conditions
    Zones
    name id type
    inlet-water 13 mass-flow-inlet
    fin-wall 4 wall
    fin-wall.1 5 wall
    pipe-wall 6 wall
    tank-wall 12 wall
    outlet-water 14 pressure-outlet
    pipe-wall-shadow 16 wall
    fin-wall.1-shadow 15 wall
    fin-wall-shadow 8 wall
    Setup Conditions
    inlet-water
    Condition Value
    Mass Flow Rate (kg/s) 1.4973
    Total Temperature (k) 325.15
    Direction Specification Method 1
    Turbulent Intensity (%) 1
    Turbulent Viscosity Ratio 5
    fin-wall
    Condition Value
    Thermal BC Type 3
    fin-wall.1
    Condition Value
    Thermal BC Type 3
    pipe-wall
    Condition Value
    Wall Thickness (m) 0.001
    Thermal BC Type 3
    Wall Motion 0
    Shear Boundary Condition 0
    tank-wall
    Condition Value
    Thermal BC Type 1
    Wall Motion 0
    outlet-water
    Condition Value
    pipe-wall-shadow
    Condition Value
    Thermal BC Type 3
    Wall Motion 0
    fin-wall.1-shadow
    Condition Value
    Thermal BC Type 3
    Wall Motion 0
    fin-wall-shadow
    Condition Value
    Thermal BC Type 3
    Wall Motion 0
    Solver Settings
    Equations
    Equation Solved
    Flow no
    Turbulence yes
    Energy yes
    Numerics
    Numeric Enabled
    Absolute Velocity Formulation yes
    Unsteady Calculation Parameters
    Time Step (s) 40
    Max. Iterations Per Time Step 20
    Relaxation
    Variable Relaxation Factor
    Density 1
    Body Forces 1
    Turbulent Kinetic Energy 0.8
    Turbulent Dissipation Rate 0.8
    Turbulent Viscosity 1
    Liquid Fraction Update 0.9
    Energy 1
    Linear Solver
    Solver Termination Residual Reduction
    Variable Type Criterion Tolerance
    Flow F-Cycle 0.1
    Turbulent Kinetic Energy Flexible 0.1 0.7
    Turbulent Dissipation Rate Flexible 0.1 0.7
    Energy F-Cycle 0.1
    Pressure-Velocity Coupling
    Parameter Value
    Type Coupled
    Pseudo Transient no
    Flow Courant Number 20
    Explicit momentum under-relaxation 0.75
    Explicit pressure under-relaxation 0.75
    Discretization Scheme
    Variable Scheme
    Pressure Second Order
    Momentum Second Order Upwind
    Turbulent Kinetic Energy First Order Upwind
    Turbulent Dissipation Rate First Order Upwind
    Energy Second Order Upwind
    Solution Limits
    Quantity Limit
    Minimum Absolute Pressure 1
    Maximum Absolute Pressure 5e+10
    Minimum Temperature 1
    Maximum Temperature 5000
    Minimum Turb. Kinetic Energy 1e-14
    Minimum Turb. Dissipation Rate 1e-20
    Maximum Turb. Viscosity Ratio 100000
    edited October 2019
    Did you scale the model in Fluent, or geometry?  Is the mass flow rate for the full model or the scaled one?
  • saifalisaifali Member
    edited November 2019
    Is it possible to share the file
