Problem from meshing to the setup in CFX
There was a problem importing the mesh from the requested file.
The importing process reported the following problem:
  Model "Model" does not have a valid mesh associated with it.
  Body B37 is an unsuppressed surface body that does not enclose
  a volume. Only 3D volume meshes can be imported. If your model
  contains valid bodies as well as surface bodies then suppress
  the surface bodies and remesh before continuing.
