2-Way FSI Highly Distorted Elm Error
Trying to simulate a simple 2-way FSI: fluid flow over a beam with a low modulus (1e4 Pa) based on the oscillating plate tutorial geometry.  Changing the mesh and transient properties has helped to a degree but the highly distorted element error persists.  The error reports that the structural component is at fault, but the animation (attached) shows Fluent's mesh distorting.  It is likely not showing the structural distortion.
Any help would be appreciated.  Attached are the workbench files, animation, and photo demonstrating the distortion.
Mesh and time steps were reduced for file size.
  • learn13learn13 Member
    edited March 2018
    Currently unable to attach workbench files.
    edited March 2018
    I've been able to resolve the issues with the model above with better mesh definitions and better understanding of coupled time stepping.
    This problem seems more resilient when reducing everything to the micrometer scale length.  The first iteration fails every time, even with end time as 1e-15 and stepping time 1e-17.  The initial 'impact' of the pressure wave and the resultant shear force is causing distorted elements.
    edited May 2018
    Resolved by shifting the analysis from 2D to 3D.
  • edited December 2019
    Could you please explain what u have done to resolve the issue? I am doing a two way FSI for blood and artery and i am getting high distortion error in transient structural in the first iteration itself.
