Slice Error
Hey aIl,
I got this error while running solution in Polyflow.
Anyone has any idea what this is about?
Summary of the simulation:
        The computation failed.
     * Expert tool diagnostics *
     An error has occured during slicing operation.
     * Expert tool Suggestions *
     This slicing error is probably due to one of the following reasons:
     1. the domain to slice is not sliceable (each slice, from inlet to
     outlet sections should have same cells/faces distribution). 2. there
     is an inconsistency between the inlet and outlet sections of the
     remeshing domain.  Please, check the inlet and oulet sections in the
     remeshing menu.
     If the problem persists, please, contact Ansys Polyflow support and
     send us, if possible the mesh, data and listing files.
     We apologize for the inconvenience.
