Implement a moving heat flux load (circle area) in Ansys Workbench via APDL command
I’m trying to implement a circle shaped heat flux with uniform (constant value) on a simple steel plate.
The circle shaped load moves along Y direction.
The circle is the result of nodes gathered from a surf element created in the first step.
Model:
Model
Step 1:
Step 1
Step 2:
Step 2
 Code:
Step 1:
/prep7                                 ! Enter into /prep7 as ET and ESURF are valid only in /PREP7
et,101,152                          ! Create a new element type for SURF152
cmsel,s,surface1                ! Select nodes on a face via Face named selection
type,101                             ! Set the element type as 101
esurf                                   ! Create surface effect elements on the selected nodes
allsel,all                              ! Select everything back
/solu                                   ! Re-enter /SOLU
wpcs,-1,0                     ! WP @ GLOBAL ORIGIN
wpof,,0.005                  ! OFFSET WP ALONG ITS Y AXIS (i.e. provide current position of center of circle along Y axis)
cswp,11,1                     ! DEFINE Cylindrical COORDINATE SYSTEM @ WP ORIGIN
esel,s,ename,,152       ! Select SURF152 elements
sfed,all,,hflux               ! Delete old flux if any
nsle                              ! Select nodes attached to selected SURF elements
nsel,r,loc,x,0,0.005      ! Select nodes within radius of circle, 0.005m
csys,0                          ! Set CSYS back to global
esln,r                           ! Select SURF elements attached to the nodes within the circle
sfe,all,,hflux,,1000    ! Apply hflux based on your calculation at the said time
allsel,all
outres,all,all
Step 2:
wpof,,0.01                   ! OFFSET WP ALONG ITS Y AXIS (i.e. provide current position of center of circle along Y axis)
allsel,all
outres,all,all
Something is missing, there is no flux applied on the SURF152 thermal elements.
Do I use an improper surf element?
Best regards,
HF
