Silicon Anisotropic elasticity
Amin1372Amin1372 Member Posts: 16
Can anyone help me to read this table? it's for Silicon Anisotropic elasticity
  • Amin1372Amin1372 Posts: 67Member
    edited January 2020
  • mrifemrife PHLPosts: 140Forum Coordinator
    edited January 2020
    Hi Amin1372
    What do you mean by read?  Explain the tables values?  If so please see the following:
    ANSYS Help -> Mechanical APDL -> Material Reference -> Chapter 3.3 Anisotropic Elasticity
    Bit too much in the help to copy/paste here.
    Mike
  • BenjaminStarlingBenjaminStarling AustraliaPosts: 118Member
    edited January 2020
    Hi Amin,
    The 1.66E+05 is your elastic modulus
    The 80000 is your shear modulus
    the 64000 is related to poissons ratio, 64000/1.66e05=0.3855
    Isotropic elasticity is a linear material model with a symmetric matrices. The D values can be read as x, y, z, xy, yz, xz. If you change the values for any one of these the element orientation becomes important as you are changing the stiffness for a given direction.
    https://ansyshelp.ansys.com/Views/Secured/corp/v195/ans_mat/anel.html
    edited January 2020
    Hi Benjamin,
    Thanks for your help. Well, if Silicon is Anisotropic material, why the elastic modulus in all directions of X, Y and Z are the same(1.66E+05)? and should the poisson's ratio be the same too?
    edited January 2020
    I actually do not know why the material is included with Anisotropic Elasticity as default. It may just be a handy exmaple of when/how to use it. It would be presumptive, and possibly risky, for ANSYS to include the Anisotropic property and then have a user implement it in a project without checking element orientations.
    Even the wood material that has been included in Granta Design Sample Materials is included with linear elasticity.
    It is better the user implement any anisotropic, or orthotropic, material properties and take responsibilty for understanding the matrix and applying element orientations.
    For the material to be anisotropic, as you have mentioned, the elastic modulus and poissons ratio can be different for each axis.
  • user8179user8179 GermanyPosts: 15Member
    edited July 2020
    Hello Dear,
    Did you find the solution? if yes please share with me. I am doing wood material simulations.
  • g_empog_empo Posts: 6Member
    Hi Benjamin,
    I was just wondering if you could clarify how you calculated that poissons ratio? Just because I am not sure it is correct and therefore do not understand where the 64000 has come from. Any help appreciated!
    Em
    The calculation is in my comment. Although something I am not entirely sure of is whether this value should be halved? Either way poissons ratio is the linear relationship between a load applied in a certain direction, and the strain experienced in a direction orthogonal to the direction of the load, which is what that calculation of 6400/1.66e5 is describing.
    If it is not clear to you I would recommend starting with structural steel, setting up two definitions, one that uses isotropic definitions, and one that use anisotropic definitions, and applying a unit load to a cube, or prism of some nominal shape. Adjust the anisotropic values until you see correlation with the isotropic definition.
