Time-dependent element birth in additive manufacturing of WAAM process during layer generation
Hello everyone,
I am currently doing a process simulation for Wire and Arc Additive Manufacturing - at the moment still of a single layer. Therefore, I am coupling a transient thermal analysis with a transient structural analyis. Regarding the thermal simulation, I am using a moving Goldak heat source (a modified version of the downloadable Add-On Moving heat source, which uses a Gaussian heatsource by default).
Since I want to model the material deposition as well, I want to make use of element birth techniques, which I want to implement via APDL commands.
The heat source gets applied within a single loadstep over the time period of 100s and consists of 100 substeps.
At first, I tried to implement a temperature-dependent element birth, which didn't work since I would need the temperature at every substep as a condition to decide whether the element gets activated or not. Thus after one substep is solved, the command has to be reentered again.(at least to my mind) Therefore, I want to implement a time-dependent element birth.
The problem I now encounter in my code is that I don't know whether parameters containing the element number get stored in the way I thought.
I hope you can understand my problem by looking at both the pictures as well as the attached APDL command file I wrote .
Philipp
Element Numbers of first row of Weld body
 General Model Overview (Baseplate and Weld)
  • edited January 11
    My APDL Command:
    ! ACTIVATE ONE ROW OF ELEMENTS AFTER TWO SUBSTEPS
    *DIM,COUNT,ARRAY,1,1,1
    *DIM,LOOP,ARRAY,1,1,1
    *DIM,EPTS,ARRAY,1,1,1
    *DIM,E1,ARRAY,1,1,1
    *DIM,E2,ARRAY,1,1,1
    *DIM,E3,ARRAY,1,1,1
    *DIM,E4,ARRAY,1,1,1
    *DIM,E5,ARRAY,1,1,1
    *DIM,E6,ARRAY,1,1,1
    ! DEFINE INITIAL LOOP PARAMETERS
    *SET,COUNT,1
    *SET,EPTS,2          ! ELEMENT ROWS (OF WELD) SELECTED PER SUBSTEP
    ! DEFINE ELEMENT NUMBERS OF FIRST ROW
    *SET,E1,301
    *SET,E2,351
    *SET,E3,401
    *SET,E4,500
    *SET,E5,550
    *SET,E6,600
    *GET,STEPTIME,ACTIVE,0,SOLU,DTIME              ! GET LOAD STEP SIZE (100s)
    *GET,STEPNUM,ACTIVE,0,SOLU,NCMSS             ! GET NUMBER OF SUBSTEPS(100x)
    *VOPER,INCR1,STEPTIME,DIV,STEPNUM            ! DEFINE START VALUE OF LOOP
    *VOPER,INCR2,INC1,MULT,EPTS                          ! DEFINE INCREMENT OF LOOP
    ! SELECT BODY (IN THIS CASE WELD)
    CMSEL,S,ELEM_TO_BIRTH_BODY,ELEM            ! COMPONENT NAME
    EKILL,ALL        ! DEACTIVATE ALL ELEMENTS
    ! RESELECT INITIAL PREDEFINED ELEMENTS
    ESEL,R,ELEM,E1      !ELEMNUM: 301
    ESEL,R,ELEM,E2      !ELEMNUM: 351
    ESEL,R,ELEM,E3      !ELEMNUM: 401
    ESEL,R,ELEM,E4      !ELEMNUM: 500
    ESEL,R,ELEM,E5      !ELEMNUM: 550
    ESEL,R,ELEM,E6      !ELEMNUM: 600
    EALIVE,ALL
    *IF,COUNT,LT,100                                   ! IF COUNT FOR SUBSTEPNUMBER IS LOWER THAN 100
    *DO,LOOP,INCR1,STEPTIME,INCR2    ! DO LOOP FROM FIRST SUBSTEP UNTIL END OF LOADSTEP
        ! WITH AND ACTIVATE NEW ELEMENT ROW EVERY TWO SUBSTEPS
        ! BECAUSE LOAD STEP TIME IS 100s and ELEMENT NUMBER IN
        ! DIRECTION OF MOVING HEAT SOURCE IS 50
    *GET,ELEMLOCINC1,ELEM,E1,NXTH  ! FIND NEXT ADJACENT ELEMENT NUMBER, ELEMNENT NUMBER
        ! GOES UP WITH DIRECTION OF MOVING HEAT SOURCE
    ESEL
    EALIVE,ALL
    *SET,E1,ELEMLOCINC1                        ! STORE NEW ELEMENT NUMBER
    *GET,ELEMLOCINC2,ELEM,E2,NXTH
    ESEL
    EALIVE,ALL
    *SET,E2,ELEMLOCINC2
    *GET,ELEMLOCINC3,ELEM,E3,NXTH
    ESEL
    EALIVE,ALL
    *SET,E3,ELEMLOCINC3
    *GET,ELEMLOCINC4,ELEM,E4,NXTL  ! FIND NEXT ADJACENT ELEMENT NUMBER, ELEMNENT NUMBER
        ! GOES DOWN WITH DIRECTION OF MOVING HEAT SOURCE
    ESEL
    EALIVE,ALL
    *SET,E4,ELEMLOCINC4                       ! STORE NEW ELEMENT NUMBER
    *GET,ELEMLOCINC5,ELEM,E5,NXTL
    ESEL
    EALIVE,ALL
    *SET,E5,ELEMLOCINC5
    *GET,ELEMLOCIN6,ELEM,E6,NXTL
    ESEL
    EALIVE,ALL
    *SET,E6,ELEMLOCINC6
    *VOPER,COUNT,COUNT,ADD,INCR1   ! INCREASE COUNT
    *ENDDO
    *ELSEIF,COUNT,GT,100    ! IF COUNT OF SUBSTEPNUMBER IS GREATER THAN 100
    FINI
    /CONFIG,NOELDB,0
    /SOLU
    *ENDIF
  • Hello Phillip,
    I hope you found a solution for your problem.
    I am currently starting to simulate a WAAM process, and learning the program. Could you recommend me some good sources I can go through to understand how to simulate WAMM on Ansys?
    Any help would be appreciated.
    Greetings,
    Daniel
