Use of surface elements SURF152 for heat flux load
I’m trying to apply a heat flux on a circle shaped area with the use of SURF152 elements via APDL command snipptes.
I apply SURF152 elements, select the nodes attached to selected SURF elements and select only the nodes within the circle radius around WPCS aka Y_p coordinate.
The code I use is subsequent following:
!BC Thermal/HFLUX:
H_FLUX=1000
Y_p=0.0
Radius=0.015
/prep7                          ! Enter into /prep7 as ET and ESURF are valid only in /PREP7
et,101,152                      ! Create a new element type for SURF152
cmsel,s,surface1                ! Select nodes on a face via Face named selection
type,101                        ! Set the element type as 101
esurf                           ! Create surface effect elements on the selected nodes
allsel,all                      ! Select everything back
/solu                           ! Re-enter /SOLU
wpcs,-1,0                            ! WP @ GLOBAL ORIGIN
wpof,,Y_P                           ! OFFSET WP ALONG ITS Y AXIS (i.e. provide current position of center of circle along Y axis)
cswp,11,1                           ! DEFINE Cylindrical COORDINATE SYSTEM @ WP ORIGIN
esel,s,ename,,152            ! Select SURF152 elements
sfed,all,,hflux                    ! Delete old hflux if any
nsle                                   ! Select nodes attached to selected SURF elements
nsel,r,loc,x,0,Radius         ! Select nodes within radius of circle, 0.005m
csys,0                               ! Set CSYS back to global
esln,r                                ! Select SURF elements attached to the nodes within the circle
sfe,all,,hflux,,H_FLUX      ! Apply hflux based on your calculation at the said time
allsel,all
outres,all,all
And my other thermal BC's:
IC,body1,Temp,25
SF,SURFACE2,CONV,20,22
ALLSEL
Problem
Does anyone know why the model isn’t working?
I’d be glad for any suggestions.
Best regards Holly F.
