Geometry in DesignModeler
Hi, is there any option how I could restrict the angle of these two lines in the picture below in the DesignModeler?
I looked at the forced conditions but I don't find anything.
The angle shouldn't be less than 180°.
Dimension the angle and don't enter numbers less than 180. Maybe the dimension will end up on the opposite side and then don't enter numbers larger than 180.
The angle depends on the other five parameters. That's why I can't dimension the angle.
Delete other dimensions so that you can dimension the angle.
Or, write equations for other dimensions that limit the angle to be greater than 180.
