How to export loads and supports nodes (Boundary Conditions) using ACT?
Hello everyone!
This is my first post as I am starting working with ANSYS at my university.
I started to learn ACT because I need to export some information from ANSYS to use in Matlab, first I exported the nodes and elements. But now I would like to obtain the nodes that corresponds to loads and supports, I know this should be possible because the input file generated contains the node IDs to solve the system of equations, but I can't find the correct commands to do it! Hope you can help me.
I share my functional code to export nodes and elements (Hope you find useful)
import os
# Mesh Data Export From ANSYS Model
def MeshDataFunc(file_name):
    MeshF=open(file_name,"w")
    #Number of nodes and elements
    meshD = DataModel.MeshDataByName("Global")
    nnodes=meshD.NodeCount
    nelem=meshD.ElementCount
    nodesID=range(1,meshD.NodeCount+1)
    elemsID=range(1,meshD.ElementCount+1)
    MeshF.write("|||||-----NUMBER OF NODES-----|||||\n")
    MeshF.write(str(nnodes))
    MeshF.write("\n")
    MeshF.write("|||||-----NUMBER OF ELEMENTS-----|||||\n")
    MeshF.write(str(nelem))
    MeshF.write("\n")
    #Print Nodes
    print "MESH NODES"
    MeshF.write("|||||-----MESH NODES-----|||||\n")
    MeshF.write("ID\t X\t Y\t Z\n")
    for meshId in nodesID:
        node = meshD.NodeById(meshId)
        print "%s    %s    %s    %s" % (meshId, node.X, node.Y, node.Z)
        MeshF.write(str(meshId))
        MeshF.write("\t")
        MeshF.write(str(node.X))
        MeshF.write("\t")
        MeshF.write(str(node.Y))
        MeshF.write("\t")
        MeshF.write(str(node.Z))
        MeshF.write("\n")
    #Print ELEMENTS
    print "MESH ELEMENT CONNECTIVITIES"
    MeshF.write("|||||-----MESH ELEMENT CONNECTIVITIES-----|||||\n")
    MeshF.write("ID\t node1\t node2\t node3\n")
    for meshId in elemsID:
        elem=meshD.NodeIdsFromElementIds([meshId])
        print "%s    %s    %s    %s" % (meshId, elem[0], elem[1], elem[2])
        MeshF.write("\t")
        MeshF.write(str(elem[0]))
        MeshF.write("\t")
        MeshF.write(str(elem[1]))
        MeshF.write("\t")
        MeshF.write(str(elem[2]))
        MeshF.write("\n")
"""////// Main //////"""
appDataPath_folder = os.getenv("USERPROFILE")
matpath=appDataPath_folder+("\Documents")
file_name=matpath+str("\MeshData.dat")
#Mesh Data Extraction Function
