Thermal topology optimization error
Hi guys
I did a typical thermal topology optimization of a square heat sink (2D), three edges are perfectly insulation, and one is constant temperature, and the surface body is internal heat generation. But there was an error message when I run: Topology Optimization does not support linked Static structural analysis which consists of temperature dependent material along with thermal loads.
Anyone could help me ?  Thank you so much
regards
