How to find RPM and torque of wind turbine
I'm studying VAWT wind turbine with Fluent using dynamic mesh 6DOF, but I don't known how to calculate RPM and torque.
The turbine rotate normally with the wind I put.
Best Regrads
Best Regrads
How are you setting the 6DOF to move with the wind? RPM will be a rate of rotation, so is a report, torque is down to the force on the blades.
