Tables in a loop
CpwtubCpwtub BerlinMember
Hi guys,I want to apply forces on nodes in a loop. Forces, I have as tables, which represents time dependent forces.  Is it possible to do this inside the loop.  i tried the following loop. But since F command waits for %tables%, so the following the looping was not possible .. Can you please help me,
*DO,I,1,3
/INQUIRE,V_D_%I%,LINES,'%I%.txt'
*DIM,V_T_%I%,TABLE,V_D_%I%,1
 *TREAD,V_T_%I%,'%I%.txt'
 n_%I%=node(0.75,1.21,%I/10%)
 F,n_%I%,FY,%V_T_%I%%
*ENDDO
Thank you
