Time step problems with thermal stress simulation
I tried a thermal stress analysis in Workbench but I have some problems with the time steps. The beginning stept is 0s and the max step is 20 s but ANSYS says that this a problem which leads to the unability to perform my simulation. I added a screenshot which shows the steps used.
Can someone explain me what I need to enter there? And moreover, what is the reason for this issue?
Wishes,
Dan
    edited March 5
    The initial time step must be larger than the minimum time step.
    Try using 5 s for Initial, 0.5 s for minimum and 20 s for maximum.
  • DanEmDanEm Member
    edited March 15
    Hi Peter,
    thanks for your answer! I tried your time settings, but Ansys still says that there is something wrong. It marks the 20 s 5 and 0.5 is not marked yellow. I do not understand why this is happening now. I tried 6 and 30 s instead of 20 but this is marked as well. Can you explain me this?
    edited March 15
    Please reply and insert a screen snaphot image of the analysis settings.
  • DanEmDanEm Member
    edited March 29
    sorry, the times are different now here. I hope that I've the right view you had asked for. What I want to do with this simulation is to get a feeling for the deformation of my part due to thermal heating. Is there something totally wrong in it?
    Wishes and be healthy,
    Dan
    edited March 30
    The initial time must be greater than or equal to the minimum time step.
    The End Time must be greater than or equal to the Maximum Time Step.
    Try this.
    End Time 20 s
    Initial Time Step 1 s
    Minimum Time Step 0.1 s. That way, the solver can reduce the time step if necessary.
    Maximum Time Step 4 s. That way, you get more than 5 results on the way to the end time.
  • DanEmDanEm Member
    edited March 31
    I have no "end time". I have Initial, min and max. How can I get this end time array?
    edited March 31
    From Transient Thermal...the third line in Step Controls, that is the End Time.
  • DanEmDanEm Member
    edited April 8
    thanks, I found it. It has a completly other name in german. ANSYS simulates something now, but it doesn't make sense, so I need to look in the simulation again.
