How to add a Non Isothermal wall Varying Only With respect to Vertical Distance?
From The Beginning of wall the Temperature is 643.16 K at the End of Wall it is 647.16 K.
Temperature is varying with respect to distance only not Time.
How to Define a Profile or add the above suitable Expression?
X Axis Distance
Y Axis Temperature
Please try out an expression similar to the following:
Temperature = 80 [K/m] * y + 643.16 [K]
Please see the screenshot below. Here you will need to use the correct 'y' coordinates based on your geometry to derive your mathematical function.
Hope this helps.
Best,
Thank You Sir. It was helpful.
Can We Use The Method (of Adding Expression) for a Variable Wall Heat Flux Boundary Conditions as well ?
Regards
Yes.
