How to slice and structure turbine rotor's inner domain?
Dear members,
I have a 3 blade wind turbine rotor drawn here along with it's rotating domain and outer domain, I have sliced the outer domain and structured it such that on mesh it became a good hex mesh.
Now on solving this the Y+ for the blade walls was found too high and I need to decrease it. of course inflation isn't an option as it spoils the whole outer hex domain and worsens the quality insanely .
I'm looking to make the inner domain structured now(see the attached), any clue how to slice that so it has edges I can give bias to in meshing ?
(note that the turbine blades and the nose are no longer bodies as I subtracted them from the inner domain and chose not to preserve tool bodies as they're solids not flow)
Current inner domain mesh (Section view)
    edited March 2020
    Have you looked at adaption on the hex mesh? Otherwise I'd just use tet or poly (for Fluent) mesh with inflation.
  • HazemHazem Member
    edited March 2020
    What's adaptation please?
    And no, I actually have to use hex mesh
    edited March 2020
    With blades, it is very very very difficult to get hex mesh in that domain. You may need to use ICEMCFD for that. So right now you will have to use inflation plus tet mesh.
    For adaption, please see following in help.
    2020 R1 > Fluent User's Guide > 48.2.55. Manage Adaption Registers Dialog Box
    Fluent User's Guide Contents 48.2.55. Manage Adaption Registers Dialog Box The Manage Adaption
    2020 R1 > Fluent Theory Guide > 29.1. Adaption Process
    Fluent Theory Guide Contents 29.1. Adaption Process The adaption process is separated
    2020 R1 > Fluent User's Guide > 38.5.1. Performing Geometry-Based Adaption
    Fluent User's Guide Contents 38.5.1. Performing Geometry-Based Adaption The Geometry Based
    Keyur
    If this helps, please mark this post as 'Is Solution' to help others.
