Goldak double ellipsoid laser welding
I use an APDL command snippet to achieve a double ellipsoid according to Goldak equation, but the Temperature rise at the end of the welding line is strange and artificial.
The APDL snippet is:
CMSEL,ALL
*GET,EMAX,ELEM,,NUM,MAX
*GET,EMIN,ELEM,,NUM,MIN
ALLSEL
TIME_WELD=80
DT=1
A=0.003
B=0.003
C1=0.004
C2=0.016
TAU=0
FF=0.6
FR=1.4
Q=1000
VEL=1.73e-3
NPT=TIME_WELD/DT
NROPT, FULL
*DO,i,1,NPT,1
WTIME=(i)
TIME,WTIME
HCENTER=VEL*WTIME
*DO,jj,EMIN,EMAX,1
X=CENTRX(jj)
Y=CENTRY(jj)
Z=CENTRZ(jj)
CSI=-Z+VEL*(TAU-WTIME)
*IF,Z,GT,HCENTER,THEN
C=C1
F=FF
*ELSE
C=C2
F=FR
*ENDIF
PART1=(6*(3**0.5)*F*Q)/(A*B*C*3.14*(3.14**0.5))
PART2=(exp(-3*(X/A)**2))*(exp(-3*(Y/B)**2))*(exp(-3*(CSI/C)**2))
QF=PART1*PART2
BFE,jj,HGEN,,QF
*ENDDO
SOLVE
*ENDDO
CMSEL,ALL
BFEDELE,ALL,ALL
ALLSEL
This is when the Laser spot leaves the plate.
Has anyone a suggestion what went wrong?
Best regards
Holly
  • cmcccmcc Member
    edited April 24
    I met the same difficulty. Have you solved the problem?I guess it's because when the reservoir leaves the solid, there's no element in the first half that causes the heat flux to change in the second half, and I don't know if I'm right.
  • SteBirSteBir Member
    edited May 26
    lost my password and therefore can't reactivate my account.
    Unfortunately, I haven't solved the problem. I think you are right, but I'm not skilled enough to implement it in the code.
    Do you have any suggestions to fix it in the code?
  • cmcccmcc Member
    edited May 27
    I think this problem arises because you use BFE to apply loads to elements, and maybe you should load the FLUX on nodes use BF,I‘m’ trying it now,If you have any progress, please tell me , thank you!
    edited June 4
    did you solve the issue? I wasn't successful.
  • KremellaKremella Admin
    edited June 8
    If you are not finding a reply here, please create a new post with your detailed question and we will be happy to help.
    Thanks.
