Elements are not visible, is this a Graphic problem
CpwtubCpwtub BerlinMember
Dear All,
I tried to produce INFIN elements in APDL. As the fist step I checked with the same example code given under EINFIN command reference( ANSYS online). picture attached----
 Even after using the same command, APDL showing following . Some elements are not visible. Is this a graphic problem ?? Do anyone know the reason
Thank you
Appreciate it a lot
