inlet velocity of a spices as a function of flow_time in transient simulation
I am solving a problem where methane is emitted from a surface and mixing with air. The velocity of emission is such that it varies with time.
it is constant for first 3600s and then decreases linearly with flow_time from 3600s to 10800s.
i am using 2019R3 version of fluent and made a curve fit with expression language for Inlet velocity as follows:
0.1475[m/s]-flow_time*0.000013194[m/s^2]
But expression doesn't seem to work as it only reads the 0.1475 [m/s] as the constant value. Can some one please advice me on the syntax or any other method to change the velocity of methane with respect to time in R3. I have also tried reading .txt file that doesn't seem to work as well.
Thanks in Advance
Samson Paul
