Is it necessary to have node coincidence between bonded surfaces?
I have this steel structure. I have a friction contact between the beams, and a bonded contact between the welds and the beams. Do I need node matching between the nodes of the beam and the nodes of the welds for an optimal solution?
No node merging
No node merging between welds and beam
