SnapFit Non-linear analysis Force Convergence Issue
AkashVyasAkashVyas Delhi, IndiaMember
I was trying to solve this snap-fit problem but I'm getting these msgs every time ever time, I'm not sure what is the issue
The material for snap is polycarbonate and for the block it's steel
Displacement
these are my analysis and contact setting
analysis setting               contact setting
and if I'm reducing the no of load steps or substeps it's not even converging till this point
    edited March 2020
    It might be that convergence was easy up to this point, and now much, much smaller steps are needed to show equilibrium as the snap moves around that corner.Try to add Stabilization in the Nonlinear Controls under Analysis Settings.  Also try much smaller elements around each corner.
    Another suggestion is to treat this as a dynamic event and simulate this using Transient Structural.
    Either way, it is going to take a long time to simulate.
  • AkashVyasAkashVyas Delhi, IndiaMember
    edited March 2020
    What stabilization settings should be used constant or reduce
    edited March 2020
    Try Reduce, but use more elements around each corner first, and use smaller time steps at the point in the simulation when the corners start to slide on each other.
    edited March 2020
    new results
    sir, I have solved this problem with fine mesh and stabilization and also I have given 35 loadsteps this time for the same dispalcement last time it was 20 loadsteps. but still same issue
    last time node count was 10525 and element count was 3301
    and this time node count is 39903 and element count is 12757
    this is the force convergence graph
    edited March 2020
    What are the goals of your analysis?
    What questions do you want the simulation to answer?
    edited March 2020
    I have to find the mating force
    edited March 2020
    Plot the data so far...
    Don't you have the mating force already?
    Isn't the convergence problem when there is a pull in force after the resistance to mating is over?
    edited March 2020
    I have the mating force, I just wanted to compare the FE generated force and hand calc force. This is just for practice
    Sorry I don't understand what do mean "Isn't the convergence problem when there is a pull in force after the resistance to mating is over?"
    Will it be okay if I plot the force till this point
    edited March 2020
    Yes, you can plot the results up to the point when the convergence failed. All the data is valid except for the last point that it adds "for debug purposes".
    Please reply with the plot of Reaction Force Probe on the insertion.
    edited March 2020
    I'm using probe tool to plot force but It's not active/ working maybe because this problem is not solved completely
    also, that file got corrupted so I'm again doing the simulation with less displacement till the point its converging
    edited March 2020
    applied forcefrictional contact force
    this time Input displacement is 6.8mm last time it was 8.2mm
    edited March 2020
    Is it possible to reduce the computation time and also file size
    It Took more than an hour to solve also file is quite large almost 4GB, I thought plain stress problem will take much less computational time and space then solid model
    edited March 2020
    Okay, you have your insertion force graph.
    Do you need the part where the snap goes around the corner and the force reverses from pushing to being pulled in as the snap closes?
    Yes, it takes time to solve.  Yes, it will take longer to solve a 3D model than a 2D plane stress model.
    edited March 2020
    Yes, I also need that part, how to solve that part
    Should I solve that separately
    edited March 2020
    Just continue the same analysis for another few hours. When convergence fails, take more substeps and make the elements smaller as necessary to continue convergence.
    There are lots of tweaks that can be done on the Frictional Contact Details to help it out.  You also should put in the Command Object
    NEQIT,100
    This will tell the solver to keep trying for 100 iterations before doing a bisection. Without that it will bisect in 26 iterations or less.
    You are waiting longer than necessary by using small elements along the entire boundary. You only need small elements where the contact is occurring. Use large elements everywhere else.
    You can also change the square to be a rigid part, then you won't get a mesh on the interior, only on the surface, but you have to use a joint to keep it fixed (or moving as the case may be).
    edited March 2020
    Okay, I will try again
