HFSS loop antenna design
I want to make a loop antenna and excite it using a square pulse. Is it possible? If possible can anyone please help me with it? any suggestion will be appreciated. I want to measure the H field at 5 cm distance after exciting it with 10kHz square pulse . Another thing is as the voltage/source is time domain here, can we generate report from HFSS that is showing frequency vs field intensity?
