Solid to surface frictional contact
Hi there,
I was searching for such problem here but did not find what I'm looking for. Basically I want to create a frictional contact between a solid a surface(shell). The case is simple, I heat up the solid and the shell plate, and the press with a force. I don't want to create a bonded contact, because I want to let the surface and solid to "slide" between each other because of the different thermal expansion level. If I make them bonded, they expand with the same magnitude of Directional Deformation, obviously. I think I might make some essential error....
Thank you in advance!
Setup:
After preheating:
After loading:
