IC fluent gets terminated in between solving at a random time steps
hello guys,
iam try to solve gdi engine with air a cold flow simulation case, in between solving upto 700-800 time steps at a certain random time step the solver(calcuation) automatically gets terminated.
these has been happen three times. when i opened the windows event viewer there is a error which shows like this:
"Log Name:      Application
Source:        Application Error
Date:          02-04-2020 005:14
Event ID:      1000
Task Category: (100)
Level:         Error
Keywords:      Classic
User:          N/A
Computer:      MSI
Description:
Faulting application name: fl_mpi1910.exe, version: 0.0.0.0, time stamp: 0x5acbac27
Faulting module name: fl_mpi1910.exe, version: 0.0.0.0, time stamp: 0x5acbac27
Exception code: 0xc0000005
Fault offset: 0x00000000034e4298
Faulting process id: 0x3cb4
Faulting application start time: 0x01d60829c315eb70
Faulting application path: C:PROGRA~1ANSYSI~1v191fluentfluent19.1.0win643ddp_nodefl_mpi1910.exe
Faulting module path: C:PROGRA~1ANSYSI~1v191fluentfluent19.1.0win643ddp_nodefl_mpi1910.exe
Report Id: a0e4f333-1510-4366-a389-444cc57e6438
Faulting package full name:
Faulting package-relative application ID:
Iam using MSI GL65 9SDK I7th -9thgen 9750H octacore with 16gigs of ddr4 and 6gb nvidia GTX1660ti using ansys 19.1
i dont know what is the problem. iam attaching fluent error logs too. using parallel job with 6cores and gpu.
This has happened almost 3 times. please help
your help is very much appreciated.
