Export results to excel
in Structures
Good Day
I am trying to get the deflection profile along the length of the rod. When I try to export the results, it gives me the excel data for all the nodes of the model. Is there a way to get the deflections of say, the lowest elements only?
Thank you,
Andy
If you add a Deformation result to the Solution branch in Mechanical and scope it to the body that is the rod, in the details window, there is a summary with the Minimum and Maximum values in the plot. That is where you can get the minimum deformation.
If that is not what you mean by "lowest elements only" please explain further.
