*ERROR* Tne normal of target element
I am trying to find deflection of composite wing. I used ACP(PRE) and defined layers and etc.etc.
When I finally set the connections, supports and load.
I am getting this error:
the problem is that, when I check the mesh it has only 32536, so I can not even see, where the elements is.
Can you please help me how to solve this ? I am using 2019.R3 version.
Thank you very much
