Parameterization Update Problem for New Design Points
Raj007Raj007 Member
Hello guys,
I have a model with a velocity-inlet and outlet. The input parameters are velocity, temperature, and radius. The output parameters are heat flux and shear stress.
When I am adding the new design point for the parameter, I am getting the following error
"Update failed for the Solution component in 2dfil for Design Point 135. Update Solution Failed"
and there is no output result.
Please help me or suggest a possible solution to generate new design points.
Thank you
Raj
