Simulation of a Water Spray
Hello everybody
I'm currently working on my Bachelor Thesis for my Mechanical Engineering degree.
The task is to simulate a water spray which is going to be injected into air as ideal gas. Both fluids need to be set as continuous fluid, so it should not be a large breakup model simulation to investigate every single drop. The nozzle diameter is 0.75mm and the injection velocity is 150 m/s.
I've already done my first setup but the result isn't quite comprehensibly. The water spray keeps cylindrical over a whole injection length of 200mm. I expect that the flow will spread after a time.
My question now is if someone has experience in modelling this kind of sprays? Do I need to add some special models or some other sort of physics? If you have some questions, please ask me!
Thanks for all replies in advance.
  • raul.raghavraul.raghav Bethlehem, PAMember
    edited May 2018
    How did you come with the geometry for your simulation? And what are the boundary conditions? 2D or 3D? Can you provide a better schematic of the geometry and how you setup the BC's?
    Which solver and what model are you using to solve this simulation?
    And if you want more information about setting up the simulation, Raef has some really good youtube tutorials on jet flow which would help you immensely:
    CFD ANSYS Tutorial - Air jet flow simulation through a nozzle revisited | FLUENT
    CFD Tutorial – Converging diverging (CD) nozzle supersonic flow | Fluent ANSYS
  • edited May 2018
    Hi Rahul
    Thanks for your answer.
    I thought since the inlet is round, I'm going to do also a cylindrical opening. So I can create an ogrid (for the inlet) in an ogrid (for the opening). I meshed everything with hexa and did a refinement on the passage area between liquid and gas fluid. The mesh quality is really good and my supervisor is quite happy with it. So, everything is 3D, see pictures:
    My boundary conditions:
    FLOW: Flow Analysis 1
    • ANALYSIS TYPE:
      Option = Steady State
      EXTERNAL SOLVER COUPLING:
      Option = None
    • DOMAIN: Default Domain
      Coord Frame = Coord 0
      Domain Type = Fluid
      Location = BODY
    • BOUNDARY: Inlet
      Boundary Type = INLET
      Location = INLET
      BOUNDARY CONDITIONS:
      FLOW REGIME:
      Option = Subsonic
      HEAT TRANSFER:
      Option = Fluid Dependent
      MASS AND MOMENTUM:
      Option = Cartesian Velocity Components
      U = 0 [m s^-1]
      V = 0 [m s^-1]
      W = 150 m/s
      TURBULENCE:
      Option = Low Intensity and Eddy Viscosity Ratio
      FLUID: Air
      HEAT TRANSFER:
      Option = Static Temperature
      Static Temperature = 298 [K]
      VOLUME FRACTION:
      Option = Value
      Volume Fraction = 0
      FLUID: Water
      HEAT TRANSFER:
      VOLUME FRACTION:
      Option = Value
      Volume Fraction = 1
    • BOUNDARY: Opening
      Boundary Type = OPENING
      Location = SIDE,BACK
      FLOW DIRECTION:
      Option = Normal to Boundary Condition
      FLOW REGIME:
      Option = Subsonic
      HEAT TRANSFER:
      MASS AND MOMENTUM:
      Option = Opening Pressure and Direction
      Relative Pressure = 1 [atm]
      TURBULENCE:
      FLUID: Air
      HEAT TRANSFER:
      VOLUME FRACTION:
      Option = Zero Gradient
      FLUID: Water
      HEAT TRANSFER:
      VOLUME FRACTION:
    • BOUNDARY: Wall
      Boundary Type = WALL
      Location = WALL
      HEAT TRANSFER:
      Option = Adiabatic
      MASS AND MOMENTUM:
      Option = Free Slip Wall
      FLUID PAIR: Air | Water
      WALL ADHESION:
      Option = None
    • DOMAIN MODELS:
      BUOYANCY MODEL:
      Option = Non Buoyant
      DOMAIN MOTION:
      Option = Stationary
      MESH DEFORMATION:
      Option = None
      REFERENCE PRESSURE:
      Reference Pressure = 0 [atm]
      FLUID DEFINITION: Air
      Material = Air Ideal Gas
      MORPHOLOGY:
      Option = Continuous Fluid
      FLUID DEFINITION: Water
      Material = Water
      Option = Material Library
      MORPHOLOGY:
      FLUID MODELS:
      COMBUSTION MODEL:
      Option = None
      FLUID: Air
      HEAT TRANSFER MODEL:
      Include Viscous Work Term = True
      Option = Total Energy
      FLUID: Water
      Include Viscous Dissipation Term = On
      Option = Thermal Energy
      Homogeneous Model = Off
      TURBULENCE MODEL:
      Option = SST
      TURBULENT WALL FUNCTIONS:
      Option = Automatic
      Surface Tension Coefficient = 0.072 [N m^-1]
      INTERPHASE HEAT TRANSFER:
      Heat Transfer Coefficient = 10 [W m^-2 K^-1]
      Option = Heat Transfer Coefficient
      INTERPHASE TRANSFER MODEL:
      Option = Free Surface
      MASS TRANSFER:
      Option = None
      SURFACE TENSION MODEL:
      Option = Continuum Surface Force
      Primary Fluid = Water
      MULTIPHASE MODELS:
      Homogeneous Model = On
      FREE SURFACE MODEL:
      Option = Standard
      INITIALISATION:
      Option = Automatic
      FLUID: Air
           INITIAL CONDITIONS:
           SET!
    Does this help? Please feel free to ask for more!
    Thank you very much for the youtube tutorials! They seem quite useful! My only question is, how adaptable is it for CFX? Can I use it as a CFX user?
  • sahilsahil Member
    edited July 10
    Hi mrglobetrotter,
    I have seen your question and project. I am working on same kind of project. can you please help me by sharing your work ( Maybe you have completed because your question is from 2018), this would be a great help to me. Thank you in advance
    Sahil
