Sprill Kill/Alive with Preload
Hi
I am trying to do interference solving for a model in the first load step and I wanted to apply spring preload in the second,
I found few commands for Ekill/Ealive for spring element, but it is not working when I am applying preload to the spring.
Does anybody know any alternative to this?
  • ekostsonekostson Member
    edited April 14
    See this video for more information on how to do that - preload can be added as usual in the spring (under connection tree)
    Erik
  • bhanu34bhanu34 Member
    edited April 14
    Hi ekostson,
    Thanks for the help, As I already mentioned,  I tried with preload and it is not working
    Without applying preload, the above commands work fine
    edited April 14
    If you are using a spring (body-body or to ground) as defined under connections and then suing the preload under the details of the spring and then do as shown in the video, then that works. I would suggest, that you make a small test example say with one cube and one body to ground spring that is not active in 1st step and then active in second, and that has the preload.
    edited April 14
    Hi
    I tried and it is not working, can you please try it and send me the archived file
    Thanks in advance
