Unable to start a New Discussion
I am unable to post. Getting "Sorry, an error occurred while processing your request. Internal error"
Please help.
Dustin Fu
Please help.
Dustin Fu
Could you please try the following?
I hope one of these options helps you post your question.
Best,
Hello Karthik,
It did not help. I am still getting error:
studentcommunity.ansys.com says
Sorry an error occurred
I've just had some stray time out errors on here: please can you try again? There is nothing different in here to the rest of the site so it's got to be something in the post (topic name or content) that's to blame. The system also dislikes brackets in certain cases.
I tried again and was able to post with text only.
When include image in the post, either "insert Image" or "attach a file" would give error.
We are looking into this issue. Thank you for bringing this to our attention. We will update you here soon.
Best,
I'm getting the same errors
I can't upload images or attachments !
Try now.
rwoolhou,
Images were inserted successfully. Thank you for fixing this problem.
dustinfu
Hi I am unable to start a new discussion. It shows me "Sorry, an error occurred while processing your request."
I have the same problem. I can not even edit my posts nor add images.
Same problem for me...
Thank you for flagging this issue. We are working internally to fix this. We will inform you here as soon as it is good to go.
Apologies for the inconvenience and Thank you for your patience.
Best,
Could you please try again and confirm if you are able to create a 'New Discussion' on the community?
Thanks.
