Multiple RPM upload from Maxwell to Harmonic Response
Hi ANSYS Community,
I am currently studying the vibrations caused by electromagnetic radial forces for motors by coupling the Maxwell simulations with Harmonic response. I have been able to successfully run the simulation for one speed of the motor to generate vibrations but I am facing problems when I try to upload multiple forces from a speed sweep using optimetrics in Maxwell.
Below are some figures of my import settings. The only option for transfer definition is Setup 1: Transient, I need this to be ParametricSetup 1 to include the multiple speeds and forces, but there is no option for this.
I was wondering if anyone knows how to properly connect the simulations so that my parametric sweep results from Maxwell upload for multiple RPMs to harmonic response instead of only the RPM defined in the transient project variable.
Thank you,
Nathan
