VOF model for slurry deposition trough an extruder
Dear,
I, as a completely new guy to Ansys, started building up a model in fluent to simulate the slurry (fluid) deposition through an extruder. First I started to get to know the software via the tutorials in VOF modelling and some overall tutorials. Then I started with a 2D-model to try it out in a simplified model. After this gave me some decent results, I started rebuilding this model in 3d with the same parameters. But when I run this, the calculated VOF surface doesn't look realistic at all with a slurry being so vicious. Especially compared to the 2D-model. And next to that it gives the floating-point error after around 40 iterations. In the attachments of this topic, I uploaded one file containing the two summary files of the model. First, the 2D model summary is given, behind that the 3D model summary
Would be pleased to have someone that could look at it and give me some tips on what to do next to get some valid results.
Sincerely,
Guus
    edited April 20
    as an Ansys employee I do not download attachments. Slow settling or no settling slurries can be modeled as non Newtonian fluid. If you require sir as surrounding then simple two phase flow with the slurry with adjusted properties and non Newtonian viscosity
    edited April 20
    that was general hint without looking into your particular case. Add some more information regarding your 3d problem
  • GuusWezelGuusWezel Member
    edited April 21
    Dear Amine,
    Thanks for your hint.
    The 3D model now consists of a nozzle at a fixed distance above a substrate. The substrate is moving in one direction to model the slurry deposition during printing. To test the model, the slurry now just has a fixed viscosity of 1 pas/s, this will later be changed to a non Newtonian viscosity.
    As a time step I use a function that changes the time step per iteration: IF(iter<=600, 1 [s] *10**-(10-iter*0.01), 0.0001 [s]) with a total of 1700 iterations.
    Down here I put the text I wrote the settings of the 3d model (the same as in the attachments).
    Fluent
    Version: 3d, dp, pbns, vof, lam, transient (3d, double precision, pressure-based, VOF, laminar, transient)
    Release: 20.1.0
    Title:
    Models
       Model                        Settings
       Space                        3D
       Time                         Unsteady, 1st-Order Implicit
       Viscous                      Laminar
       Heat Transfer                Disabled
       Solidification and Melting   Disabled
       Species                      Disabled
       Coupled Dispersed Phase      Disabled
       NOx Pollutants               Disabled
       SOx Pollutants               Disabled
       Soot                         Disabled
       Mercury Pollutants           Disabled
       Structure                    Disabled
    Material Properties
       Material: slurry (fluid)
          Property                        Units     Method     Value(s)
          Density                         kg/m3     constant   7260
          Cp (Specific Heat)              j/kg-k    constant   1006.43
          Thermal Conductivity            w/m-k     constant   0.0242
          Viscosity                       kg/m-s    constant   1
          Molecular Weight                kg/kmol   constant   28.966
          Thermal Expansion Coefficient   1/k       constant   0
          Speed of Sound                  m/s       none       #f
       Material: air (fluid)
          Density                         kg/m3     constant   1.225
          Viscosity                       kg/m-s    constant   1.7894e-05
       Material: aluminium (solid)
          Density                kg/m3    constant   2719
          Cp (Specific Heat)     j/kg-k   constant   871
          Thermal Conductivity   w/m-k    constant   202.4
    Cell Zone Conditions
       Zones
          name    id   type
          fluid   3    fluid
       Setup Conditions
          fluid
             Condition       Value
             Frame Motion?   no
             Mesh Motion?    no
    Boundary Conditions
       Zones
          name              id   type
          wall-fluid        1    wall
          symmetry-plane    6    symmetry
          pressure-outlet   7    pressure-outlet
          moving-wall       8    wall
          velocity-inlet    9    velocity-inlet
       Setup Conditions
          wall-fluid
             Condition                  Value
             Wall Motion                0
             Shear Boundary Condition   0
             Contact Angles             (((constant . 2.0943948) (profile  )))
          symmetry-plane
             Condition   Value
          pressure-outlet
             Condition   Value
          moving-wall
             Condition                                            Value
             Wall Motion                                          1
             Define wall motion relative to adjacent cell zone?   yes
             Velocity Magnitude (m/s)                             0.01
             Contact Angles                                       (((constant . 1.5707963) (profile  )))
          velocity-inlet
             Condition                  Value
    Solver Settings
       Equations
          Equation          Solved
          Flow              yes
          Volume Fraction   yes
       Numerics
          Numeric                         Enabled
          Absolute Velocity Formulation   yes
       Unsteady Calculation Parameters
          Time Step (s)                   2.5118864e-09
          Max. Iterations Per Time Step   20
       Non-Iterative Solver Factors
          Variable          Max. Corrections   Correction Tolerance   Residual Tolerance   Relaxation Factor
          Pressure          10                 0.25                   0.0001               1
          Momentum          5                  0.05                   0.0001               1
          Volume Fraction   5                  0.05                   0.0001               1
       Linear Solver
          Variable          Solver Type   Termination Criterion   Residual Reduction Tolerance
          Pressure          F-Cycle       0.1
          X-Momentum        Flexible      0.1                     0.7
          Y-Momentum        Flexible      0.1                     0.7
          Z-Momentum        Flexible      0.1                     0.7
          Volume Fraction   Flexible      0.1                     0.7
       Pressure-Velocity Coupling
          Parameter   Value
          Type        Fractional Step
       Discretization Scheme
          Variable          Scheme
          Pressure          PRESTO!
          Momentum          QUICK
          Volume Fraction   Compressive
       Solution Limits
          Quantity                    Limit
          Minimum Absolute Pressure   1
          Maximum Absolute Pressure   5e+10
          Minimum Temperature         1
          Maximum Temperature         5000
    I hope you now have a general idea of the problem and that you can help me further.
    Sincerely,
    Guus van Wezel
    edited April 21
    What is now the problem?
    edited April 21
    Dear Amine,
    The problem is that the results of the 2D and 3D models are very different. Where the 2D model gives a realistic flow of the slurry, the 3D model does not give a realistic flow at all. This is shown in the figure below.
    Model results of the 2D model (on top) and the 3D model (below)
    Since the input parameters for both models are the same, I can't locate the problem within the model.
    Sincerely,
    Guus
