"The Requested S data is not available, the PLNSOL command is ignored" error
I written a code for ANSYS Mechanical evaluating loads on a cylinder. I have fixed the geometry and can get the deformation contour plot that I want. The problem is when I try to obtain the Von Mises stress contour plot it gives me the error "The Requested S data is not available, the PLNSOL command is ignored". When I input other codes I have done in the past I am able to get the stress contour plots, so I am not quite sure what the problem is. My desktop is too small to change the launcher settings from Use Distributed Computing" to "Use Shared Memory Parallel"  and since other codes work I don't think this is necessarily the problem. Thank you for the help. I have attached my code.
