Spaceclaim Scripting
Hi all,
I am trying to automate a process in spaceclaim. My goal is to import an STL file, extrude it and save it as STEP file. I could record the script in the spaceclaim software and it works perfectly fine. I would like to run the script directly from the command terminal without manually opening the software. Any help would be appreciated. Thank you very much.
Prabhu.
