Mesh with nodes that do not coincide
How can I solve this problem ? The nodes do not coincide and are displaced from one another
    edited May 19
    where did you create this mesh?
    is it workbench meshing?
    are these bodies in different parts in SpaceClaim (or design modeler)?
    Please create multibody part and use share topology.
    please see help manual for more details.
    Keyur
    If this helps, please mark this post as 'Is Solution' to help others.
  • VICTORVERGAVICTORVERGA Member
    edited May 20
    Hi kanade,
    I created this geometry using the MPDL, here is the code:
    ! MATERIAL CONCRETO
    fc = 33.50 ! 33.50 N/mm2 +- 2.5
    Ec = 28640 ! 28640 N/mm2
    nu_c = 0.19
    ! Define microplane model properties
    k0 =
    k1 =
    k2 =
    gamma = 10e-3
    alpha = 0.96
    beta = 400
    c = 4
    ! MATERIAL ACO
    fy = 500 ! 33.50 N/mm2 +- 2.5
    Es = 210000 ! 210000 N/mm2
    nu_s = 0.3
    DAP = 12.7
    AP = PI*DAP**2/4
    ! MODELO
    /PREP7
    !  CONCRETO
    ET,1,SOLID185
    ! Define elastic properties of material
    TB,ELAS,1
    TBDATA,1,Ec,nu_c
    TB,MPLANE,1,,6,ORTH ! TB,MPLAN,mat,ntemp,npts,tbopt
    TBDATA,1,k0,k1,k2,gamma,alpha,beta ! TBDATA,1,C1,C2,C3,C4,C5,C6
    ! C1 = k0 Damage function constant
    ! C2 = k1 Damage function constant
    ! C3 = k2 Damage function constant
    ! C4 = gamma Critical Equivalent strain energy
    ! C5 = alpha Maximum degradation
    ! C6 = beta  Rate of degradation
    !  AÇO
    ET,2,LINK180
    MP,EX,2,Es
    MP,PRXY,2,nu_s
    ! Define steel nonlinear properties
    TB,BISO,2
    TBDATA,2,fy,0
    ! Define steel section
    SECTYPE,1,LINK
    SECDATA,AP
    ! GEOMETRY
    /PREP7
    A=1212.5
    B=210
    D=152
    L=9900
    RECTNG,0,A,0,B
    !RECORTES PARA ARMADURAS
    NPRESS = 5
    ESP = 190
    WPSTYL,DEFA
    WPROTA,,,90
    WPOFFS,,,56.25
    ASBW,ALL
    *DO,I,1,NPRESS,1
        WPOFFS,,,ESP
        ASBW,ALL
    *ENDDO
    WPSTYL,DEFA
    WPROTA,,,90
    WPOFFS,,,56.25+150
    ASBW,ALL
    *DO,I,1,NPRESS,1
        WPOFFS,,,ESP
        ASBW,ALL
    *ENDDO
    ! CORTES HORIZONTAIS
    WPSTYL,DEFA
    WPROTA,,-90
    WPOFFS,,,30 ! ARMADURA
    ASBW,ALL
    WPSTYL,DEFA
    NUMCMP,area
    ! FUROS
    ASEL,NONE
    CYL4,131.25,B/2,0,,D/2,360
    CYL4,131.25+190*1,B/2,0,,D/2,360
    CYL4,131.25+190*2,B/2,0,,D/2,360
    CYL4,131.25+190*3,B/2,0,,D/2,360
    CYL4,131.25+190*4,B/2,0,,D/2,360
    CYL4,131.25+190*5,B/2,0,,D/2,360
    ALLSELL
    ASBA,2,27
    ASBA,6,28
    ASBA,8,29
    ASBA,10,30
    ASBA,12,31
    ASBA,26,32
    ! CORTES HORIZONTAIS ADICIONAIS
    WPSTYL,DEFA
    WPROTA,,-90
    WPOFFS,,,90
    ASBW,ALL
    WPOFFS,,,30
    ASBW,ALL
    !RECORTES VERTICAIS ADICIONAIS
    NPRESS = 5
    ESP = 190
    WPSTYL,DEFA
    WPROTA,,,90
    WPOFFS,,,56.25
    WPOFFS,,,60
    ASBW,ALL
    *DO,I,1,NPRESS,1
        WPOFFS,,,ESP
        ASBW,ALL
    *ENDDO
    WPSTYL,DEFA
    WPROTA,,,90
    WPOFFS,,,56.25
    WPOFFS,,,60
    WPOFFS,,,30
    ASBW,ALL
    *DO,I,1,NPRESS,1
        WPOFFS,,,ESP
        ASBW,ALL
    *ENDDO
    WPSTYL,DEFA
    NUMCMP,kp
    NUMCMP,line
    NUMCMP,area
    ALLSEL
    VEXT,ALL,,,,,L/2
    ! COMPONENT PRESTRESSED REINFORCEMENT
    KSEL,S,KP,,32,39
    LSLK,S
    LSEL,R,LOC,Z,-L/2,0
    CM,AP,LINE
    ! COMPONENT CONCRETE
    VSEL,S,VOLU,,ALL
    CM,CONC,VOLU
    CMSEL,NONE
    ALLSEL
    VPLOT
    !  ATTRIBUTES
    CMSEL,S,CONC
    VATT,1,,1
    CMSEL,S,AP
    LATT,2,,2,,,,1
    ALLSEL
    !  MESH
    LESIZE,ALL,10
    CMSEL,S,CONC
    VSWEEP,ALL
    CMSEL,S,AP
    LMESH,ALL
    Thank you
    edited May 20
    How can I define the share topogy through APDL ?
