AAS commands for writing Input/Output Parameters is not working
evabe235evabe235 Member Posts: 2
Good evening,
Im using AAS- to couple Matlab and Fluent and use it as a Server. I have followed the steps in the official Ansys Youtube tutorial for the connection, and have read the users guide: "Fluent as a Server".
Most of functions seem to work such as: tui.doMenuCommandToString(), fluent. getNrInputParameters(); fluent.getInputParameterNameByIndex(in long lInputParameterIndex);
Nevertheless, the most important functions that I need do not work: (WRITE AND READ PARAMETERS of Fluent)
fluent.getOutputParameterValueByName(string('q_rad_thorax'))
fluent.setInputParameterValueByName(string('T_head'), 200)
I write an example of what Im coding:
%%%%%%%%%%%%%%% CODE %%%%%%%%%%%%%%%%%%
%% Basic Connection %%%% RUN THIS SECTION - Once per matlab session
orb=initialize_orb();
load_ansys_aas();
fluent=actfluentserver(orb,'aaS_FluentId.txt');
tui=fluent.getSchemeControllerInstance();
tui.doMenuCommandToString('report summary')
%tui.doMenuCommandToString('define operating-conditions gravity yes 9.8 0.0 0.0');
MATLAB OUTPUT ERRORS:
>> fluent.setInputParameterValueByName(string('T_head'),200)
Java exception occurred:
AAS_CORBA.EFluentGenericError: IDL:AAS_CORBA/EFluentGenericError:1.0
at AAS_CORBA.EFluentGenericErrorHelper.read(EFluentGenericErrorHelper.java:80)
at AAS_CORBA._ICoFluentUnitStub.setInputParameterValueByName(_ICoFluentUnitStub.java:456)
at AAS_CORBA._ICoFluentUnitStub.getOutputParameterValueByName(_ICoFluentUnitStub.java:579)
PD: I have already written in my Fluent case these parameters previously, so they exist. I have also tried writing fluent.getOutputParameterValueByName('q_rad_thorax') and neither works. Here below I attach the error that I get from at FLUENT command window: unbound-variable, set-parameter-data
Thank you very much,
Any help would be really welcome.
  • KremellaKremella Posts: 2,497Admin
    edited June 2020
    I'm trying to find you the right person to answer your question. Thank you for your patience.
  • jannavjannav Posts: 2Member
    I have similar problem. I'm using Matlab 2017b and Fluent 2019 R1. When I try to run Fluent calculation by command:
    >> iFluentTuiInterpreter.doMenuCommandToString('solve iterate 100')
    It starts calculation but immediately Matlab gives an error and calculation stops:
       at AAS_CORBA._ICoFluentSchemeControllerStub.doMenuCommandToString(_ICoFluentSchemeControllerStub.java:126)
    Is there any solution?
    Thank you
    Jan
  • SteveSteve Posts: 155Forum Coordinator
    Is this the video you're looking at? https://www.youtube.com/watch?v=td0rV_4IXI4
    Do you have access to the customer portal to download the example files? I'm not sure what the issue could be at this stage.
