Missing ::libudf in Hooking step for UDF code
ANSYSCOMPANSYSCOMP Member
Hello
I try to simulate a udf code for DPM body force. My code has been interpreted successfully. In hooking step, I noticed that in my box the ::libudf is missing.
Does anyone have experience with this to help me out or give me any hints?
For the compilation approach, I installed VS2012 (ANSYS 17.0) but I need how can I create a header file.
    edited May 28
    1/Are you able to compile any other UDF?
    2/There is no magic: copy the example from the manual and compile it after that load it (check that you are loading the libudf) then hook it there in the UDF/DPM Panel.
  • ANSYSCOMPANSYSCOMP Member
    edited June 1
    Hello Sir
    Thank you for your reply.
    I compiled the udf's code : Body force in the manual and the problem is solved now for ::libudf.
    I am trying to adapt this code for mine.
    I have a remark: When I injected the body force in my model (Flow over flat plate), the result didn't change as a flow without body force.
    edited June 2
    Check if you are running two way and scale the force perhaps requires tuning.
    edited June 3
    Hello SIr
    There is my udf's code :
    For hooking step , my DISCRET PHASE MODEL BOX is setting up as (after injection's step) :
       *  Physical models    : Pressure gradient force
       * udf                            : - Body_particle_force::libudf
                                              - number of scale    2
    My questions :
    Could you please check my code and DPM box setting up ?
    How can I verify that my calculation  has integrated the udf's code?
     Thank you so much.
    edited June 3
    Please start from the manual: your UDF is doing nothing. There is no return value.
