Help with Reinforced Concrete to Steel column hybrid connection
I am currently trying to creat a hybrid connection which connects reinforced concrete directly to a steel column. I have used SOLID65 for the concrete and LINK180 for the rebar. I searched for what i believe is most of the data for doing reinforced concrete on this site thus far and used the collected information to make this model.
I am currently trying to understand why the model simply does not work. If i use any other material for the "concrete slab", the model runs fine and i get results. However, when i use the Solid65 and rebar(LINK180) commands the model only fails. (ERROR "An unknown error occurred during solution" and "Linear Tetrhedral elements have been used in regions with linear materials"
IMAGE ATTACHED SHOWS QUARTER MODEL OF STEEL COLUMN CONNECTION. NOTE THE STEEL SECTIONS GO INTO THE CONCRETE SLAB
THe contact type is bonded connection
COMMANDS FOR SOLID65
ET,MATID,SOLID65
R,MATID,0,0,0,0,0,0
RMORE,0,0,0,0,0
MP,EX,MATID,29250
MP,PRXY,MATID,0.2
MPTEMP,MATID,0
TB,CONCR,MATID,1,9
TBTEMP,22
TBDATA,1,0.3,0.8,3,-1
TB,MISO,MATID,1,35,0
TBTEMP,22
TBPT,,0.0001,2.925
TBPT,,0.0002,5.7
TBPT,,0.0003,8.325
TBPT,,0.0004,10.8
TBPT,,0.0005,13.125
TBPT,,0.0006,15.3
TBPT,,0.0007,17.325
TBPT,,0.0008,19.2
TBPT,,0.0009,20.925
TBPT,,0.001,22.5
TBPT,,0.0011,23.925
TBPT,,0.0012,25.2
TBPT,,0.0013,26.325
TBPT,,0.0014,27.3
TBPT,,0.0015,28.125
TBPT,,0.0016,28.8
TBPT,,0.0017,29.325
TBPT,,0.0018,29.7
TBPT,,0.0019,29.925
TBPT,,0.002,30
TBPT,,0.0021,30
TBPT,,0.0022,30
TBPT,,0.0023,30
TBPT,,0.0024,30
TBPT,,0.0025,30
TBPT,,0.0026,30
TBPT,,0.0027,30
TBPT,,0.0028,30
TBPT,,0.0029,30
TBPT,,0.003,30
TBPT,,0.0031,30
TBPT,,0.0032,30
TBPT,,0.0033,30
TBPT,,0.0034,30
TBPT,,0.0035,30
*SET,ELEM_TYPE_ID,101
ET,ELEM_TYPE_ID,solid65
KEYOPT,ELEM_TYPE_ID,1,0
KEYOPT,ELEM_TYPE_ID,3,2
KEYOPT,ELEM_TYPE_ID,5,0
KEYOPT,ELEM_TYPE_ID,6,0
KEYOPT,ELEM_TYPE_ID,7,1
KEYOPT,ELEM_TYPE_ID,8,0
COMMANDS FOR LINK180
ET,matid,LINK180
MPDATA,EX,matid,,2e5
MPDATA,PRXY,matid,,0.3
TB,BISO,matid,1,2
TBDATA,,355,2100,,,,
R,matid,314.14,,0 !Area of Rebar
PREPROCESS COMMANDS
/PREP7
ESEL,S,ENAME,,65
ESEL,A,ENAME,,180
ALLSEL,BELOW,ELEM
CEINTF,0.00001, !controls mesh of rebar
ALLSEL,ALL
/SOLU
OUTRES,ALL,ALL
EQSLV,SPARSE,1.0E-8,3.0,,
BCSOPTION,,INCORE,16000,,,OFF
SOLCONTROL,ON,OFF,NOPL,
NROPT,unsym,,on
neqit,200
KBC,0
cutcontrol,plslimit,0.2
LNSRCH,OFF
cutcon,noshape,1
THANK YOU FOR YOUR HELP
