Critical Error
jd1310jd1310 Member Posts: 1
I am trying to install Student Software 2020 R1 and I am getting critical error. One solution that I have read is to delete uninst_data.dat but I can't find it in the folder where I extracted the zip file downloaded from ansys website.
I have read a few threads but I couldn't solve my problem.
I have also re-downloaded the software and tried the installation again but no luck! my drive space is nearly 30 GB
I would also like to notify that I have 2019 R3 version installed already.
  • tsiriakstsiriaks 3240 El Camino Real #290, Irvine, CA 92602Posts: 3,071Forum Coordinator
    edited June 2020
    Have you tried the following command in CMD Prompt
    Another thing to try is to go to the folder in your screenshot, then browse in 'prereq' folder and manually run all the installers here one-by-one. Make sure they are all successful. You can skip the opencl and MPI related ones. You may need to reboot after this.
    If that doesn't help, please provide the following info
    Open Windows Event Viewer  -> Custom Views -> Administrative Events , then see if there is any error event related to crashing logged in here. Another location you can check is -> Windows Logs -> Application . Post screenshots of all relevant errors to this installation
    In CMD Prompt, enter the following command
    set
    then post the output of it here.
  • MrHauptMrHaupt Posts: 0Member
    Hi, I have followed these instructions as I am having the same problem and none of them worked
    Here is my output for CMD command set.
    Hi, I have followed these instructions as I am having the same problem and none of them worked Here is my output for CMD command set.
    What directory is your installation package in ?
    Try turning off all security on the machine during the installation
    Do you have any event logged in the Windows Event Viewer ?
  • AnsysxcrashAnsysxcrash Posts: 2Member
    Hi, sir I have the same issue. Could you please help me fix it. I have already lost count of the number of times i reinstalled.
    And I checked my event viewer>applications and it showed error. What should i do about it?
    Have you tried the 2 suggestions above ?
    please also post the details of that error in Event Viewer.
  • fazazahirafazazahira Posts: 1Member
    Here is the event viewer on my screen. Then what should I do with all the warnings there?
