ANSYS 14.5 running but window not shown
in Systems
Above is the Task Manager, showing that ANSYS is running, but my problem is ANSYS window could not function, meaning I can't use the ANSYS interface, no graphic appears (as shown in the image below). How to solve this problem?
Solved, refer to this link https://studentcommunity.ansys.com/thread/my-ansys-workbench-19-2-opens-but-doesn-t-open/. Type your version of ANSYS then the problem would be solved. For example, if your ANSYS version is 16.5, replace 192 with 165, problem solved.
