Simulating Inductive PCB Sensor at MHz
which tool (Maxwell or HFSS) is the best to simulate the signals (in voltage) generated by induced eddy currents with 3 MHz ? The sensor is composed of one primary excitation coil and two receiver coils (see attachment). The primary coil is inducing eddy currents within a copper plate.
My goal is to see the reactions from the receiver coils due to the interference with the eddy currents.
  • rtkrtk Pune, IndiaForum Coordinator
    edited June 15
    As you requirement is for simulate signals induced with 3 MHz, I would suggest to go with Ansys Maxwell, which will fulfill your requirement.
    For further procedural check please refer to Maxwell help document.
