2-way system coupling error
I'm trying to simulate a fluid-structure interaction with Fluent and Transient Structural. When I start solving the system coupling, the error message below appears:
Update failed for the Solution component in System Coupling. The coupling service failed to start.
Association: C3.
Can someone tell me where the problem is?
Hi, I am also getting same error while solving two way coupled fsi so please let us know what should do in this case.
Thank you
Regards
How are you setting up your model? What are your Data Transfer? Have you attempted to start the Mechanical and Fluent simulations separately? Did you receive any error message when you run these simulations separately?
Hi Kremella, I have getting same error. I used both static structural+steady fluent and transient structural+transient fluent, but I have got same error. I have tried complete analysis in structural and fluent, they work.
Additionaly, I have got these explanations in soluion information:
| Warnings were found during data model validation. |
| Restart output is only requested at last step. To enable restarts from |
| intermediate points, use another 'OutputControl' option. |
| Participant CouplingParticipant:Solution 1 has the ExecutionControl |
| 'Option' set to 'ExternallyManaged'. System Coupling will not control |
| the startup/shutdown behavior of this participant. |
| Participant CouplingParticipant:Solution has the ExecutionControl 'Option' |
| set to 'ExternallyManaged'. System Coupling will not control the |
Awaiting connections from coupling participants...
| "System coupling solution stopped before all participants connected. A |
| solver failure occurred during the run in the Static Structural system"
Do u have any idea about that problem?
Damla
Hi @damladrms , @Abbu2u,
I recommend following these steps when encountering problems with System Coupling.
Steve
