Problem with changing the SOLID187 to SOLID65 for concrete component
Dear community,
I having a problem with changing the SOLID187 to SOLID65 for a concrete component.
I had tried using the following command:
et,matid,solid65
MP,Ex,matid,1500
MP,Prxy,matid,0.2
MP,Dens,matid,2400e-9
TB,concr,matid
tbdata,1,0.3,1,0.304,4.27
and then change Element Control to Manual.
However, the command hasn't worked and an error occurs (Element type 1 is not the same shape as SOLID65). It shows SOLID187 is used in the solution information.
Any advice on this problem?
Thank you very much in advance for your help and time.
