How to run two loading cases and get the maximal stress in every element?
OscarEspinosa95OscarEspinosa95 Samara, RussiaMember
Hi, I'm running an bunch of analyses in MAPDL's batch mode. I can't figure how to run two loading cases and get the maximal stress in every element. I have the next file .dat for the batch mode execution:
/NERR,,,-1
/PREP7
CDREAD,DB,'C:\Users\OSCAR\MATLAB2APDL','cdb',,'',''
CPINTF,ALL,0.0001,
/SOLU
SOLVE
/POST1
SET,LAST
ETABLE,SEQV,S,EQV      !\theta_eqv
ETABLE,VOL,VOLU,       !V
SMULT,G,SEQV,VOL       !\theta_eqv*V
SSUM                   !G = \sum \theta_eqv*V
/OUTPUT,g,txt
*GET,G,SSUM,0,ITEM,G
/OUTPUT
As output I get the file g.txt, which have the next format:
 *GET  G         FROM  SSUM  ITEM=ITEM G         VALUE= 0.923886702E+12
By the moment I obtain the value for one loading case, how can I run two loading cases and get the maximum Von Mises stress from both cases?
Also, as you can see, the file have empty lines. I need to get rid of this lines and the text before the value, I mean, just get the number.
