Piezo and MEMS Extension install error
I am using ANSYS 17.1 version while installing Piezo and MEMS extension gives the error as shown below:
Error while reading xml: Root element missing
Pls help how to resolve this issue?
    edited June 2020
    Can you try moving the entire ACT package to be under C:\Temp and load it from there ?
    Also, try opening CMD Prompt and issue the following command
  • ravishekravishek Member
    edited June 2020
    I have tried as u suggested above but still the error remains the same.
    What we have tried so far:
    Renaming %APPDATA% Ansys folders
    Uninstalling Ansys and reinstalling
    Tried it with different versions (17.1 / 19 / 2019 / 2020)
    Deleting environment variable
    Deleting registries and reinstalling
    Even tried to install other extensions, no luck
    Everything had be done running the installation as administrator
    Error while reading xml 'C:\Program Files\ANSYS Inc\v201\Addins\ACT\extensions\LSDYNA.wbex' : Root element is missing.
    Error while reading xml 'C:\Program Files\ANSYS Inc\v201\aisol\WBAddins\MechanicalExtensions\AdditiveWizard.wbex' : Root element is missing.
    Error while reading xml 'C:\Program Files\ANSYS Inc\v201\aisol\WBAddins\MechanicalExtensions\AqwaLoadMapping.wbex' : Root element is missing.
    Error while reading xml 'C:\Program Files\ANSYS Inc\v201\aisol\WBAddins\MechanicalExtensions\BladeInterference.wbex' : Root element is missing.
    Error while reading xml 'C:\Program Files\ANSYS Inc\v201\aisol\WBAddins\MechanicalExtensions\ExternalStudyImporter.wbex' : Root element is missing.
    Error while reading xml 'C:\Program Files\ANSYS Inc\v201\aisol\WBAddins\MechanicalExtensions\MechanicalDropTest.wbex' : Root element is missing.
    Error while reading xml 'C:\Program Files\ANSYS Inc\v201\aisol\WBAddins\MechanicalExtensions\MotionLoads.wbex' : Root element is missing.
    Error while reading xml 'C:\Program Files\ANSYS Inc\v201\aisol\WBAddins\MechanicalExtensions\Offshore.wbex' : Root element is missing.
    Error while reading xml 'C:\Program Files\ANSYS Inc\v201\aisol\WBAddins\MechanicalExtensions\VariableLoad.wbex' : Root element is missing.
    List of running applications:
    Error while reading xml 'C:\Temp\PiezoAndMEMS.wbex' : Root element is missing.
    WebPage: file:///C:\Program Files\ANSYS Inc\v201\Addins\ACT\html\gridpanel.html?ACTPort=52695&ACTSocketName=Log
    As you can see, Ansys yet is not even opening the preinstalled addins.
    We have no idea what is wrong here
    edited June 2020
    still getting error pls help?
    edited June 2020
    Hi guys
    Good news finally it worked for me:
    Open Windows 10 control panel, Choose Region (Note down your current region type, since you might need to revert back to it if other software on your machine is dependent on your current region setting)
    change to Format: English(United Kingdom)
    Apply
    OK
    Make sure that the decimal systems is set to dot "." not comma "," (under 'Additional settings')
    With this setting, ACT extension will work.
  • John2020John2020 Member
    edited June 2020
    thanks for your help sincerely and it also works for me
    edited June 2020
    Wow !! Good find !
    I didn't expect that this issue has anything to do with localization.
    Thank you for sharing.
  • Thanks for sharing. I had a same problem. It worked for me too.
  • Hello,
    Thank you guys it works for me also 😀😆😄
