Floating point error with Extreme velocities entering at junction
Dear all,
I work with 3D, Transient, VOF(Water and air), Open Channel problem with 'Flow past row of cylinders mounted at the bottom wall'.
I run fluent in parallel mode. The code crash with floating point error as shown below.
Divergence detected in AMG solver: omega
turbulent viscosity limited to viscosity ratio of 1.000000e+05 in 889546 cells
 Error at host: floating point exception
Error at Node 0: floating point exception
Error at Node 1: floating point exception
Error at Node 2: floating point exception
Error at Node 3: floating point exception
Error at Node 4: floating point exception
Error at Node 5: floating point exception
===============Message from the Cortex Process================================
Compute processes interrupted. Processing can be resumed.
 Error: floating point exception
 Error Object: #f
When i plot velocity vectors, i observe velocities of extreme values are entering at one of the junction location of cylinder and bottom wall.the snapshot is attached.xrtreme velocities
Kindly help. Thanks in advance.
Prabu
    edited June 24
    Case diverged so velocities are garbage. Add more details about the run.
  • PRABUPETERPRABUPETER Member
    edited June 24
    Geometry: The problem has a 3d rectangular prism domain, with open channel vof, whose boundary condition are as follows
    left end-pressure inlet(with water level and velocity), right end-pressure outlet.
    front face-symmetry;back face-symmetry;top face-symmetry; bottom face-wall;
    It has slender cylinders emerging from bottom wall to top symmetry.
    Meshing: tetrahedral mesh; meshing quality: skewness less than 0.8, min orthogonality:0.2
    solver: transient,rans, sstkw,methods: piso, body force weighted, implicit, second order discretisation(u,v,w,k,w)
    the problem is solves a flow past vertical cylinders in parallel processing. The solver brings floating point error.
    edited June 24
    Probably wrong pressure field resulting in divergence. Do you know the pressure at inlet. You need to be careful here for open channel flow as presure inlet is just providing information about total height. f you  know the height and other thing like velocity probably you might use open channel wave too (much more easy to interpret).
    Have you started using a smaller tome step size
    edited June 24
    Actually, the pressure boundary conditions worked well for the no cylinder case. But it gives error in the presence of cylinder. The height of the water and the inlet velocity is known aprior. The time step is 0.001 s. what could be the reasons for getting this error.
    Kindly help,
    Prabu
    edited June 24
    What's the mesh like around the cylinders?
    edited June 24
    For the meshing around the cylinders, I used both with and without inflation, as shown below.
  • rahkumarrahkumar Member
    edited June 25
    Can you run the simulation by reducing the relaxation factors?
    edited June 27
    Rahul,
    These are the values i used for under-relaxation pressure 0.3; density 1; body-force 1; mom 0.7; mp 0.5; k 0.8; omega 0.8; turb-viscosity 1
    Prabu
